A blast from the past.
While browsing a 1996 backup of an old computer of mine, I found a directory with my dabbling exercises in Personal REXX 2.0 in the late 80ies.
And, lo and behold, there I found some examples - bundled with the program - from Namir's review of the product on BYTE.
Here's one:
/*______________________________________________________________________________*/
/*ROOT.REX Accompanies the review, "Personal REXX" by Namir Clement Shammas, Byte, January 1988, page 167*/
/* Root seeing using Newton's method */
/* Personal REXX version */
NUMERIC DIGITS 10
NUMERIC FORM SCIENTIFIC
SAY 'Enter expression (of variable X) '
pull fstring
fstring = 'Y = '||fstring
SAY 'Enter guess and accuracy '
pull guess accr
diff = 2 * accr
iter = 0
MAXITER = 30
DO WHILE ABS(diff) > accr
IF ABS(guess) > 1.0 THEN h = 0.01 * guess; ELSE h = 0.01
SAY 'guess = ' guess
diff = 2.0 * h * FF(guess) / (FF(guess + h) - FF(guess - h))
guess = guess - diff
iter = iter + 1
IF iter > MAXITER THEN diff = 0
END
SAY ' '
SAY ' '
SAY 'Root = ' guess
SAY ' '
SAY 'Number of iterations = ' iter
EXIT
FF: PROCEDURE EXPOSE fstring
arg X
INTERPRET fstring
/* variable Y is part of the interpreted fstring */
RETURN Y
Serendipity... :)
BYTE
Ahhhhh ......Great magazine , brings back memories
Holy cow!
Used to manage a VM/ESA system. Used EXEC2 & REXX a lot. Often wrote my own quick & dirty stuff in REXX. Always impressed me between REXX and XEDIT/macros the amount of power you could have; realatively easily.
Is Personal REXX still available? Wouldn't mind a full(er) version of XEDIT that ran under Windows or DOS also. Guess I could search.
How often I missed the VM system; though somewhat perculiar it was.
(09-09-2018 05:36 AM)Duane Hess Wrote: [ -> ]Holy cow!
I started on VM/CMS and VM EXEC.
(09-09-2018 05:36 AM)Duane Hess Wrote: [ -> ]Is Personal REXX still available? Wouldn't mind a full(er) version of XEDIT that ran under Windows or DOS also. Guess I could search.
You could try
Regina REXX or
Open Object REXX.
Regarding XEDIT, there's
KEDIT (but
hurry up, if you really want it ;) )
(09-09-2018 05:36 AM)Duane Hess Wrote: [ -> ]How often I missed the VM system; though somewhat perculiar it was.
I loved it too.
(09-09-2018 10:34 AM)Massimo Gnerucci Wrote: [ -> ]You could try Regina REXX or Open Object REXX.
Regarding XEDIT, there's KEDIT (but hurry up, if you really want it
I loved it too.
I just sent the company an email asking them to release it to the Public Domain. Many other companies have done this when they stopped selling software. There's a benefit for hobbyists and no downside for the company.
(09-07-2018 11:32 AM)Massimo Gnerucci Wrote: [ -> ]A blast from the past.
Here's one:
NUMERIC DIGITS 10
pull fstring
pull guess accr
diff = 2 * accr
iter = 0
MAXITER = 30
iter = iter + 1
END
SAY ' '
SAY ' '
SAY 'Root = ' guess
SAY ' '
EXIT
arg X
INTERPRET fstring
RETURN Y
Serendipity...
Has anyone tried to run this in Regina REXX? I get an error:
2*x^2+3*x-12
5 .0001
guess = 5
38 +++ INTERPRET fstring
22 +++ diff = 2.0 * h * FF(guess) / (FF(guess + h) - FF(guess - h))
Error 64 running "D:\Program Files\rexx.org\Regina\demo\NewtonsRoot.rexx", line 38: [Syntax error while parsing]
Error 64.1: [Syntax error at line 38]
Of course I haven't run REXX since my OS/2 days so I may be entering the data wrong.
(09-10-2018 12:14 PM)toml_12953 Wrote: [ -> ]Has anyone tried to run this in Regina REXX? I get an error:
I assume you have to write that expression as:
Thomas is right (as usual...)
D:\ReginaREXX391w64>regina.exe root.rex
2 * X**2 + 3 * X - 12
5 0.001
guess = 5
guess = 2.695652174
guess = 1.925113151
guess = 1.814140206
guess = 1.811738817
Root = 1.811737692
Number of iterations = 5
(09-08-2018 06:34 PM)Zaphod Wrote: [ -> ]BYTE
Always loved BYTE.
What would Jerry Pournelle have to say about current computers?
Geoff
We can use the
Complex-Step Derivative Approximation mentioned in
Derivatives on HP 42S to calculate with a single subroutine call both \(f(x)\) and \(f'(x)\) in
Newton's method:
\(x_{n+1}=x_{n}-{\frac {f(x_{n})}{f'(x_{n})}}\)
00 { 34-Byte Prgm }
01▸LBL "NEWTON"
02 STO "x"
03 RCL "h"
04 COMPLEX
05 XEQ "FF"
06 COMPLEX
07 RCL÷ "h"
08 ÷
09 STO- "x"
10 RCL "x"
11 END
For the equation \(2x^2+3x-12=0\) of the given example this program can be used:
00 { 19-Byte Prgm }
01▸LBL "FF"
02 2
03 RCL× ST Y
04 3
05 +
06 ×
07 12
08 –
09 END
Initialisation
1E-8
STO "h"
Iteration
5
XEQ "NEWTON"
y: 2.30434782609
x: 2.69565217391
R/S
y: 0.77053902071
x: 1.92511315320
R/S
y: 1.10972947392E-1
x: 1.81414020581
R/S
y: 2.40138878229E-3
x: 1.81173881703
R/S
y: 1.12553786619E-6
x: 1.81173769149
R/S
y: 2.47260969077E-13
x: 1.81173769149
(09-10-2018 12:52 PM)Thomas Klemm Wrote: [ -> ] (09-10-2018 12:14 PM)toml_12953 Wrote: [ -> ]Has anyone tried to run this in Regina REXX? I get an error:
Thank you! The exponentiation symbol (**) had dropped from my memory entirely!
