(09-06-2018 03:32 AM)Tim Wessman Wrote: [ -> ]CAS does not support the concept of fixed width integers. The author has no interest in adding them as it does not fit with CAS type operations.
Similarly, we've done our best to make units work properly, but we have no control over the CAS handling of units.
Well, small price to pay considering how extensive it is
compared to the old HP 49/50 series CAS (or the original HP 40 CAS).
This is the first time ever I'm not going to teach myself all the commands 100%.
I found the HP Prime CAS Command set PDF available in English:
https://www-fourier.ujf-grenoble.fr/~par...me_cas.pdf
It seems that the integrated version 1.49 does not contain absolutely every command.
The document is most likely not properly adapted for the HP Prime.
I didn't list every capitalized name/NAME version difference - only: rref 138 & xor, 197
The page numbers are off thus I couldn't check the functions quickly.
!=, 196, 507; %e, 196; %i, 196; %pi, 196; &&, 197; &*, 324; &ˆ, 324; /laplace, 95; ||, 197; ‘’, 61
angleat, 423; angleatraw, 423; areaat, 424; areaatraw, 424
bounded_function, 67
Celsius2Fahrenheit, 374; colSwap, 317; comment, 491; common_perpendicular, 377
distanceat, 425; distanceatraw, 426
euler_gamma, 196
fadeev, 328; Fahrenheit2Celsius, 374; false, FALSE, 196; frac, 204
InputStr, 491; integrate, 76; is_coplanar, 443
mRowAdd, 323
norm, 290
ofnom, 57
pcoef, 157, 163; perimeterat, 427; perimeteratraw, 428; plotdensity, 190; POLYFORM, 306
ramn, 332; rand, 229; randmatrix, 332; rootof, 155; rref, 138, 329
slopeat, 428; slopeatraw, 429; snedecor, 239; snedecor_cdf, 242; snedecor_icdf, 246; sq, 199; srand, 236; sturm, 171
table, 271; time, 41; true, TRUE, 196
UTPC, 236; UTPF, 236; UTPN, 237; UTPT, 237
xor, 197
ΔLIST, 285; ΠLIST, 286; ΣLIST, 286
_______________________________________
Note that the catalog on the calculator (PC Emulator) might be outdated.
Also there are MORE commands that are listed in the document index.
Finally, there's a general (PC?) version PDF-document here:
https://www-fourier.ujf-grenoble.fr/~par...cmd_en.pdf
