Quote: EE_Analysis.hpprgm
EEVARS.hpprgm
EELIBRARY.hpprgm
EE Library.hpappdir.zip
You are saying that we can delete everything and then install ONLY "EE Library.hpappdir" and it will work fine? Or are you saying that we need to delete everything (those of us who already have your previous version "library" installed), and then install BOTH "EE Library.hpappdir" and "EE_Analysis" because "EE Library.hpappdir" lacks something that "EE_Analysis" has?
The explanation below is directed at all users in general and may clear up some misconception between Local and Global variables even if it was not part of the question above.
1-
EE_Analysis: This program runs on its own. It contains some topics found in
EELIBRARY like Ohms Law and Power. The reason for the duplication is that in the
Solver, Ohms Law and Power cannot use
Complex Numbers or Units, but in EE_Analysis it can. The same is applicable to Series and Parallel Circuits, Delta to Wye, Mesh analysis, etc.
2-
EEVARS: This part contains all the variables that are used by
EELIBRARY
These variables such as (ΔVCE, ΔTj) are declared with the
EXPORT command and become
Global Variables and can be used by the Prime from the Command line in Home, in Apps or anywhere else just like
A to Z,θ. Without declaring these variables the Solver App is limited to (Prime's Global variables).
EELIBRARY will not run without EEVARS. You must run EEVARS at least once before running EELIBRARY.
3-
EELIBRARY: Is a compilation of
Equations only,which are found in most
Engineering/Electronic text books.
EELIBRARY will not run without first and once running EEVARS.. The equations are loaded in the
Solver App and use the variables declared by
EEVARS.
4-
EE Library APP: is a combination of
EELIBRARY and EEVARS.
When EE Library is not running the variables are not available. They are as
Local variables, which when any Program that uses Local variables only is terminated, the variables are also terminated.
in summary you can use:
1- (EE
LIBRARY + EEVARS )
but not EELIBRARY by itself.
2- (EE Library
APP) by itself).
3- (EE_
Analysis + EELIBRARY + EEVARS) .
4- (EE_Analysis + EE Library
App).
"Best choice." Since these two Program can call each other via the last option in the Main Menus.
If you use
Option 4 it would make sense to
delete EELIBRARY and EEVARS from your Program List. :-)
I welcome any questions or suggestions which can be beneficial to this Library.
Bernard
