(08-10-2018 12:28 PM)Dieter Wrote: [ -> ]nmax is stored in the n-register
That's a clever idea for the
HP-12C.
(08-09-2018 10:15 PM)Albert Chan Wrote: [ -> ]I had revised my Python code after your HP-11C translation. Now:
1. hi = lo + 1 instead of 1/0 (infinity), thus saved 1 iteration
2. Both abs() calls are removed
These are the relevant lines:
n1, d1 = int(x), 1
n2, d2 = n1+1, 1 # hi = lo + 1
pick_hi = (n2/d2 - x) < (x - n1/d1)
return (n2, d2) if pick_hi else (n1, d1)
In both cases we use that \(\frac{n1}{d1} < x < \frac{n2}{d2}\).
This allows to remove squaring the differences in:
47 RCL 0
48 RCL 3
49 RCL 4
50 /
51 -
52 ENTER
53 x
54 RCL 0
55 RCL 1
56 RCL 2
57 /
58 -
59 ENTER
60 x
61 x≤y?
Instead we can just use:
47 RCL 3
48 RCL 4
49 /
50 RCL 0
51 -
52 RCL 0
53 RCL 1
54 RCL 2
55 /
56 -
57 x≤y?
Kind regards
(08-10-2018 05:02 PM)Thomas Klemm Wrote: [ -> ]In both cases we use that \(\frac{n1}{d1} < x < \frac{n2}{d2}\).
Fine. This saves four lines to that GTO 66 becomes GTO 62.
Here is a revised version:
01 STO 0
02 INTG
03 STO 1
04 1
05 STO 2
06 STO 3
07 RCL 0
08 FRAC
09 x=0?
10 GTO 62
11 Clx
12 STO 4
13 RCL 1
14 RCL 3
15 +
16 STO 5
17 RCL n
18 RCL 2
19 RCL 4
20 +
21 STO 6
22 x≤y?
23 GTO 25
24 GTO 47
25 RCL 5
26 RCL 0
27 RCL 6
28 x
29 x≤y?
30 GTO 36
31 RCL 5
32 STO 1
33 RCL 6
34 STO 2
35 GTO 13
36 -
37 x=0?
38 GTO 44
39 RCL 5
40 STO 3
41 RCL 6
42 STO 4
43 GTO 13
44 RCL 6
45 RCL 5
46 GTO 00
47 RCL 3
48 RCL 4
49 ÷
50 RCL 0
51 -
52 RCL 0
53 RCL 1
54 RCL 2
55 ÷
56 -
57 x≤y?
58 GTO 62
59 RCL 4
60 RCL 3
61 GTO 00
62 RCL 2
63 RCL 1
64 GTO 00
Dieter
Discovered a
pick_hi bug:
If x = midpoint between the Farey pair, it always pick n1/d1, but n2/d2 might be better.
Example: x = midpoint of a Farey Pair
farey(111/308, 20) => 5/14 --> 4/11 is better
farey( 51/130, 15 ) => 5/13 --> 2/5 is better
It is not technically wrong, but we prefer smaller denominator.
Patch below:
diff = 2*d1*d2*x - (n1*d2 + n2*d1) # x vs Farey Pair midpoint
if diff == 0: diff = d1 - d2 # x is midpoint, pick smaller d
return (n2, d2) if diff > 0 else (n1, d1)
(08-09-2018 11:13 AM)Thomas Klemm Wrote: [ -> ]As we know \(\frac{113}{355}\) is closer for a long time. We have to wait until \(\frac{33215}{104348}\) to get closer
Hi, Thomas,
If you meant closer from below (i.e fraction < 1/Pi), above is correct.
However, if closer in absolute term, you don't have to wait that long.
For semiconvergent better than 113/355, solve for k
1/Pi - 113/355 = 2.703e-8 = (106 + 113k)/(333 + 355k) - 1/Pi
k ~ 145.8
If k >= 146, the fraction is closer.
For k = 146, we get 16604/52163, absolute error = 2.697e-8
(08-11-2018 02:13 AM)Albert Chan Wrote: [ -> ]If you meant closer from below (i.e fraction < 1/Pi), above is correct.
Exactly. I just checked when would it switch from \(\frac{113}{355}\) to the next value:
113 355 32876 103283
113 355 32989 103638
113 355 33102 103993
33215 104348 33102 103993
Sorry for my poor wording.
Thanks for clarifying
(08-09-2018 10:15 PM)Albert Chan Wrote: [ -> ]1. hi = lo + 1 instead of 1/0 (infinity), thus saved 1 iteration
(08-10-2018 07:06 PM)Dieter Wrote: [ -> ]Here is a revised version:
01 STO 0
02 INTG
03 STO 1
04 1
05 STO 2
06 STO 3
07 RCL 0
08 FRAC
09 x=0?
10 GTO 62
11 Clx
12 STO 4
Thus we can still save an iteration using:
01 STO 0
02 INTG
03 STO 1
04 1
05 STO 2
06 STO 4
07 +
08 STO 3
09 RCL 0
10 FRAC
11 x=0?
12 GTO 62
Best regards
Quote:999 [n]
3,141592654 [R/S] => 355 [X↔Y] 113
Now I wonder how long all this takes on an original hardware 12C... ;-)
Just acquired an Original HP-12C (made in Singapore) ran this and took
about 40 seconds.
Gamo
