07-29-2018, 10:19 PM
Some updates:
I. (IRAM not preserved) - I found that wiping all Android data and starting again resolved this issue, so indeed my state file was somehow corrupted.
II. (Can't remove rom image) Very Strange: If I use a rom image file called "JPCF05.ROM", the problem persists, even after wiping all Android app data, however if I change the filename to "jpcf05.rom" then it works as expected. I see Didier also had success with an image file with lower case filetype.
It makes no sense to me that the filetype case should have any effect...
I also confirmed other rom images (all named "something.rom" and not "SOMETHING.ROM") work as expected, including in Port-3.
Even stranger: When I tried to rename "JPCF05.ROM" to "JPCF05.rom" (using Android File manager) I was getting error messages saying that "folder already existed" (note there are no folders within the folder I am working). Perhaps Android has file renaming issues due to cached filenames?
My thanks to JLouis and Didier for testing and follow-up comments. As time allows, I suggest you uninstall and delete the imported image from the emulator, then rename the file and import and install again to see if this problem is unique to my system.
FYI, I'm using a Moto Z Force Droid, running Android 8.0.0.
