07-19-2018, 09:54 PM
New Functionality and Changes (Calculator Software)
1. ROUND and TRUNC now interpret DMS inputs in a more expected manner (e.g. ROUND(45°29′57.7″,4) ----> 45°29′58″ )
2. Numeric only PRODUCT function created which helps reduce change of symbolic results in unexpected places such as Sequence app
3. INPUT previously had issues with local variables being given as input. Place EVAL( ) around your definition to programmatically create INPUT boxes.
LOCAL a:= { ... }; INPUT(EVAL(a));
4. Power below 10% will now display a red critical icon in the title bar.
5. Integration when done from HOME or in an app will now always numerically evaluate rather than symbolically. This will help prevent unanticipated results when a simple numeric answer is expected
6. Added a TDim variable to control screen dim time - default is 30 seconds
7. CAS updated to later version with many improvements and fixes:
a. Improves symmetrical numeric integrals (e.g. inputs like ∫(normald(0,1,X),X,-10000.,10000.); )
b. Implemented subdiagonal extraction with diag(matrix,index)
c. Implemented hamdist(list,list) in addition to int,int
d. Handles things like ∫(e^(-x^2-i*t*x),x,-∞,∞) directly
e. gramschmidt now accepts 0 as optional 2nd argument if 1st arg is a matrix to avoid normalization
f. Implemented support for replace(string,string,string)
New Functionality and Changes (Connectivity Kit)
1. Closes update windows automatically upon completion
2. Unzips firmware file to new location inside "<Documents>\HP Connectivity Kit\Firmware"
Resolved issues and changes excluding CAS
1. Resolved issue with colors not saving properly after exiting Notes
2. Resolved issue with ARC colors if the angle_1<0 and angle_2>pi
3. Resolved issue with nested loops containing a CAS internal function not working (e.g. Σ calling a CAS function inside)
4. Resolved issue with DIMGROB only working with 16bit color but not 32bit
5. Resolved issue with clicking at very end of Chars browser
6. Resolved issue with Solve app not working with user defined variables as expected
Resolved issues and changes in CAS
1. Resolved issue with permuorder([3,8,6,5,4,1,2,7])
2. Resolved issue with complex_mode and cZeros
3. Resolved issue with int(sin(x),x,0,inf)
4. Resolved issue with solve ∫(e^(-a*x^2+b*x+c)*polynomial,x,-∞,∞)
5. Resolved issue with a:=x *(x - (exp(x) - exp(-x)) / 2 / ((exp(1) - exp(-1)) / 2)); b:=int(a); simplify(diff(b)-a);
6. Resolved issue with assume(x,integer); additionally(x>0); solve(x^2=2);
7. Resolved issue with ∫(sin(x^2),x) in degree mode
8. Resolved issue with ∫(e^x*sin(x^2),x)
9. Resolved issue with approximate integrals with identical lower and upper boundaries
10. Resolved issue with randperm(-5)
http://ftp.hp.com/pub/calculators/prime/...180706.zip
Please report any issue or bug on this thread
