07-16-2018, 02:34 PM
I understand that most people use external text editors on the PC to edit their Prime programs.
Nevertheless one should be able to work comfortable on the Prime itself at least to change and correct programs. We have the program editor for this purpose.
What I find annoying is the seemingly constant key repeat rate in this program editor. When I use one of the arrow keys to move the cursor over a longer line I would expect some acceleration when I press and hold a cursor key. The repeat rate seems to be constant which gives a sluggish impression.
It would be nice if some acceleration could be implemented e.g. starting after 5 repeats and reducing the interval down to maybe 1/4 of the initial rate within the next 5-10 repeats or so. Different users might prefer different acceleration rates. This is most annoying in the horizontal direction, the vertical direction is not so cumbersome because the jumps from line to line are larger. But even there a maybe more limited speedup could be useful.
Or did I miss something in the configuration parameters?
Martin
Martin
