Recently I saw this Casio Calculator model MP-12R state that this calculator is best choice for the "Warehouse"
Functions specifically for warehouse operations.
The main feature is the Remainder Calculation.
More information about this model:
https://www.casio-intl.com/mea/en/calc/products/MP-12R/
This reminded me of the "Long Division" I posted in this forum before and here is the updated version.
Example: 960 ÷ 360
960 [ENTER] 360 [R/S]
Answer: 240 [X<>Y] 2
Quotient 2
Remainder 240
Program: Long Division
Quote:01 X<>Y
02 ENTER
03 ENTER
04 Rv
05 Rv
06 CLx
07 Rv
08 ÷
09 LSTx
10 X<>Y
11 INTG
12 x
13 LSTx
14 Rv
15 -
16 X<>Y
17 Rv
18 GTO 00
Gamo
Hello Gamo.
I remember laughing at this calculator when it brought up this feature because I knew I could program it into my 12C. Although they probably would laugh at me for having more than several calculators.
You have a very unorthodox method of getting the answer. Very neat. This encourages me to show my program. It only consumes 8 steps although I would add an extra swap command at the end of my program just so I could have the remainder in the Y register. But it is a great feeling to create a program in the 12C and not convert any registers so I didn't.
01- /
02- LSTX
03- SWAP
04- INTG
05- SWAP
06- LSTX
07- FRAC
08- *
And I remember you like examples so I'll borrow yours for a second.
Example: 960/360
960 [ENTER] 360 [R/S] --> 240 [SWAP] 2
Thanks Carson
Any idea is very welcome this give many different variations of styles in programming.
I do have another version but used 3 registers I didn't include in this post because I know this will upset Dieter who don't like to use register if necessary so I try this all using stacks manipulation. Anyway I learn a lot from Dieter and thank you for his many tricks and tips.
HP-12C is a very capable calculator it's just can do many math related things that people didn't expect that it can do.
Gamo
(07-14-2018 08:05 AM)Carsen Wrote: [ -> ]You have a very unorthodox method of getting the answer.
Actually Gamo's method is not unorthodox but the preferred approach as it (mostly) avoids roundoff errors.
You should never use FRAC when calculating the modulus as it may and will cause errors. Consider your example: the result is not 240 but 240,0000001. Then try 960 and 7, this returns a remainder of 0,999999700.
(07-14-2018 08:05 AM)Carsen Wrote: [ -> ]I would add an extra swap command at the end of my program just so I could have the remainder in the Y register.
Agreed. Here is my attempt. Like your version (and unlike Gamo's) it does not require a double ENTER to separate the two arguments. The initial commands push Y to the higher stack levels and then drop it down again.
01 ENTER
02 ENTER
03 CLX
04 ×
05 +
06 ÷
07 LSTx
08 X<>Y
09 INTG
10 ENTER
11 R↓
12 ×
13 -
14 X<>Y
960 [ENTER] 360 [R/S] => 2 [X<>Y] 240
(07-14-2018 08:05 AM)Carsen Wrote: [ -> ]But it is a great feeling to create a program in the 12C and not convert any registers so I didn't.
That's one of the biggest advantages of RPN. You can do many things directly on the stack, without any data registers.
Dieter
(07-14-2018 05:08 PM)Dieter Wrote: [ -> ][quote='Dieter' pid='100448' dateline='1531588120']
Ah. I understand now. Thank you for pointing out this error and I'll keep this in mind.
(07-14-2018 05:08 PM)Dieter Wrote: [ -> ]The initial commands push Y to the higher stack levels and then drop it down again.
I should remember the power of the T register when I program because I didn't think of using the T register at all when making my own program.
(07-14-2018 09:44 AM)Gamo Wrote: [ -> ]HP-12C is a very capable calculator it's just can do many math related things that people didn't expect that it can do.
Agreed. The power of programming is great.
Here is another version for 11C or 15C by using the custom make program for the INT function to see the speed.
LBL A
LSTx
X<>Y
>H.MS
>H.MS
FIX 0
RND
FIX 0
x
LSTx
Rv
X<>Y
Rv
RTN
Example: 960 ÷ 360
960 [ENTER] [ENTER] 360 f [A]
Answer: 420 [X<>Y] 2
Gamo
Been a long time since no update for this Long Division routine.
This time the answer start with Quotient and Remainder.
Program:
01 ÷
02 ENTER
03 ENTER
04 LSTx
05 X<>Y
06 FRAC
07 x
08 X<>Y
09 INTG
Example: 1800 ÷ 240
1800 [ENTER] 240 [R/S] 7 [X<>Y] 120
Answer: Q = 7 and R = 120
Gamo 7/2021
