07-03-2018, 05:37 PM
Multi command app displays all functions in the CAS/Rewrite menu with their results in a popup menu on CAS main screen. Additionally, it displays expand,proot(in second menu only),collect,lncollect functions and their results.
There are 2 menu page in the app. In the first page, results are filtered, if function returns same expression with the entered, the funtion and its result aren't shown in that menu. To see all without filtered select "All Functions" at the end of the menu.
INSTALLATION:
- Copy code and paste in to "mc" named file.
- Open "mc" and press check (you would get error, ignore the error(esc))
- Go to Cas home screen and write mc(1) then enter (it returns check_mc_code text)
- Go to code file "mc" and check again. You get "no error" message .
- ready to use. example .mc(sin(2x))
Opinions and suggestions, bug reports are welcome.
*UPDATED 07-10-2018: The Issue which i mentioned below has been resolved and some functions added under the polynomial section
List of functions
-Polynomial
CAS.proot()
CAS.divis()
CAS.factors()
-Algebra
CAS.simplify()
CAS.collect()
CAS.expand()
CAS.factor()
(The app involves all Cas/Rewrite menu functions)
-Rewrite-> Main
CAS.lncollect()
CAS.powexpand()
CAS.texpand()
-Rewrite-> Exp&Ln
CAS.exp2pow()
CAS.pow2exp()
CAS.exp2trig()
CAS.expexpand()
-Rewrite->Sine
CAS.asin2acos()
CAS.asin2atan()
CAS.sin2costan()
-Rewrite->Cosine submenu
CAS.acos2asin()
CAS.acos2atan()
CAS.cos2sintan()
-Rewrite->Tangent
CAS.atan2asin()
CAS.acos2atan()
CAS.tan2sincos()
CAS.halftan()
-Rewrite->Trig
CAS.trigsin()
CAS.trigcos()
CAS.trigtan()
CAS.atrig2ln()
CAS.tlin()
CAS.tcollect()
CAS.trigexpand()
CAS.trig2exp()
INSTALLATION:
List of functions
-Polynomial
CAS.proot()
CAS.divis()
CAS.factors()
-Algebra
CAS.simplify()
CAS.collect()
CAS.expand()
CAS.factor()
-Rewrite-> Main
CAS.lncollect()
CAS.powexpand()
CAS.texpand()
-Rewrite-> Exp&Ln
CAS.exp2pow()
CAS.pow2exp()
CAS.exp2trig()
CAS.expexpand()
-Rewrite->Sine
CAS.asin2acos()
CAS.asin2atan()
CAS.sin2costan()
CAS.acos2asin()
CAS.acos2atan()
CAS.cos2sintan()
-Rewrite->Tangent
CAS.atan2asin()
CAS.acos2atan()
CAS.tan2sincos()
CAS.halftan()
-Rewrite->Trig
CAS.trigsin()
CAS.trigcos()
CAS.trigtan()
CAS.atrig2ln()
CAS.tlin()
CAS.tcollect()
CAS.trigexpand()
CAS.trig2exp()
