hello
1. Can hp prime calculate the Area of Polygon using the X,y Coordantes ?
I need to draw the Polygon with the given coordnates and calculate the Area.
2. Can Hp prime calculate the Azimuth of lines / points ?
thanks for help
Have you looked at the geometry app?
Use the cmd/polygon/polygon function to create a n point polygon.
Then use the cmd/measure/area function to calculate the area.
You can also do it from the cas command line: area(polygon(point1, ... pointn)) where point is a complex number with the point coordinates.
As for azimuth, this can also be done in the geometry app using the angle measure tool.
Cyrille
(07-02-2018 05:46 AM)cyrille de brébisson Wrote: [ -> ]Hello,
Cyrille
Boa noite
Tenho uma variável de matriz "M0" com duas colunas com valores de norte e este de um perímetro e gostaria de plotar um polígono no gráfico "G0".
Saudações.
[Moderator Gene:] English please if possible. Google translation is below.
good evening
I have an array variable "M0" with two columns with values of north and east of a perimeter and would like to plot a polygon in the graph "G0".
Greetings.
