06-20-2018, 09:02 PM
It lives! It’s working 100% ok.
Thanks to this thread below.
http://www.hpmuseum.org/cgi-sys/cgiwrap/...read=12608
It just needed a little aluminum foil wrapped around the terminal leads.
Im using a shapeways plastic power pack with a copper dual coiled spring
Question, is there a more permanent solution for the terminal leads?
The aluminum foil falls off when the pack is pulled out.
I can solder, but dont want to mess up the 25c terminal leads and do it incorrectly.
