06-07-2018, 11:26 PM
The attached ZIP file contains the Teenix MultiCalc program card files and program listings for the 19 programs in the HP-67/97 Math Pac I application set. Also provided is a quick reference sheet in US Letter and A4 format (I hope!). The sheet lists the program name to flash card image mapping when the programs are loaded as a library into the MultiCalc or Classic board hardware. The 19 programs included in the Application Pac are
\(\bullet\) Factors and Primes
\(\bullet\) GCD, LCM, Decimal to Fraction
\(\bullet\) Base Conversions
\(\bullet\) Optimal scale for a graph; Plotting
\(\bullet\) Complex Operations
\(\bullet\) Polynomial Solutions
\(\bullet\) 4x4 Matrix Operations (2 cards)
\(\bullet\) Solution to f(x)=0 on an interval
\(\bullet\) Numeric Integration
\(\bullet\) Gaussian Quadrature
\(\bullet\) Differential Equations
\(\bullet\) Interpolations
\(\bullet\) Coordinate Transformations
\(\bullet\) Intersections
\(\bullet\) Circles
\(\bullet\) Spherical Triangles
\(\bullet\) Gamma Function
\(\bullet\) Bessel Functions, Error Function
\(\bullet\) Hyperbolics
The programs should be of immediate use to those who have the PC-based MultiCalc emulator program or one of the hardware hosts. The listings should also prove useful to those with a Woodstock ACT or LP board who might want to enter programs and save them to flash. Lastly of course, anyone with an HP-67 or 97 but without the Math Pac cards will find the listings much easier to read than those found in the back of the manual.
As usual, the Math Pac I manual can be found on the MoHPC USB flash drive. Also, many thanks to Tony (Teenix) for the effort put into making the MultiCalc emulators available!
~Mark
\(\bullet\) Circles
~Mark
