06-02-2018, 01:14 AM
Hello, I leave a proposal
create the templates to export to hpprime, xcas, rpl, ... language
More info>
http://www.flowgorithm.org/
http://www.flowgorithm.org/documentation.../index.htm
Quote:Flowgorithm is a free application that allows you to create programs using graphical flowcharts. So, you can concentrate on the algorithm's logic rather than all the nuances of a typical programming language. You can also execute your programs directly in Flowgorithm.
Once you understand programming logic, it is easy for you to learn one of the major languages. Flowgorithm can interactively convert your flowchart to over 18 languages. These include: C#, C++, Java, JavaScript, Lua, Perl, Python, Ruby, Swift, Visual Basic .NET, and VBA (used in Office).
This new version adds customizable program templates in the Source Code Viewer. This means that Flowgorithm will be able to produce source code in any pseudocode or programming language. The developer simply needs to create a template.
More info>
