05-25-2018, 02:24 PM
Neat book, i'm trying to follow the first problem:
Optimization: Area of a Triangle HP Prime:
"Let A be a point located at the vertex opposite the base of an isosceles triangle.
Point C lies on a circle cantered at A whose radius is [AB]. Find the location of C that will maximize the area
of the triangle ABC."
"The area of the triangle and the length of its base may be
calculated by pressing MENU/COPY button.
We make use of the command buttons labelled area.
We will shift the position of the point C and for each location of C,
record the resulting area."
"In this way, we may obtain a number of value pairs (base; area),
which may be stored in a table. Select the application
Statistics 2Var“ by pressing X^2 button."
"Each pair of values (base; area) is entered into the table
(by pressing Menu)." <== THIS IS THE KICKER
Everything gets completely obliterated (ie: just does NOT work) when i try to press the Menu/Copy button in order to copy the Geometry data to the Statistics 2 Var App.
I am using the latest firmware.
Can someone please solve for me the problem of getting geometry data into the statistics 2 var spreadsheet. <== Needed Solution
MANY THANKS IN ADVANCE!
