Full Version: fixed. Problem with : operator
Hello, when writing an identifier that ends in two points, the emulator is blocked
a: [enter]
the error was detected when trying to assign to a:=1, after erasing "=1"
Yes. My emulator after entering a: shut down completely. Physical one did reboot.
True, it happens in the CAS
Seems to be fixed in my development version, I get a syntax error (this is probably a side-effect of early implementation of Python syntax compatibility). Fortunately, I don't believe many users will try to write an identifier with a : inside, : is not a valid char inside a variable name.
Fixed =), thanks hp-prime team
"HP Prime Graphing Calculator
Software Version: 2.0.0.13865 (2018 07 06)
Hardware Version: Emu
CAS Version: 1.4.9 6x
