05-21-2018, 09:31 AM
Nth term of a Geometric Sequence giving
Initial Value (a)
Common Ratio (r)
Term (n)
Formula: a sub n = ar^n-1 for every integer n ≥ 1
More information about Geometric Progression:
https://en.wikipedia.org/wiki/Geometric_progression
Example:
a=2
r=3.14
n=14
Procedure:
Set User Mode
2 A > 2 // Input initial value
3.14 B > 3.14 // Input common ratio
14 C > 14 // Input term
D > 5769197.69 // answer on the 14th term
What is the sequence number on the 1st and 2nd term on the above example?
(1st Term) 1 C > D > 2
(2nd Term) 2 C > D > 6.28
The sequence are 2, 6.28, 19.72, 61.92,.......
Program:
Remark:
The common ratio of a geometric sequence may be negative, resulting in an alternating sequence, with numbers switching from positive to negative and back. For instance
1, −3, 9, −27, 81, −243, ...
is a geometric sequence with common ratio −3.
Input 1 A, -3 B, and your choice of term [C] then [D] for answer.
This update version can be use for the following:
LBL A // To display a geometric progression
LBL B // To find from the n-th term
LBL C // To find the sum of the giving n-th term
Procedure:
For geometric sequence: (a) ENTER (r) > f [A] > continue [R/S]
For n-th term: (a) ENTER (r) ENTER (n) > f [B]
For the Sum of given n-th term: (a) ENTER (r) ENTER (n) > f [C]
Example:
a=1
r= -3
n= selected term
Sequence: 1, -3, 9, -27, 81, -243,......
Geometric Sequence: 1 ENTER -3 f [A] > 1 > [R/S] > -3 > [R/S] > 9
4th term: 1 ENTER -3 ENTER 4 f [B] > -27
Sum to 4th term: 1 ENTER -3 ENTER 4 f [C] > -20
Program:
Gamo
Initial Value (a)
Common Ratio (r)
Term (n)
Example:
a=2
r=3.14
n=14
Procedure:
Set User Mode
Program:
LBL A // Initial Value
STO 1
RTN
LBL B // Common Ratio
STO 2
RTN
LBL C // n-term
STO 3
RTN
LBL D
RCL 2
X>0? // Test Common Ratio for Positive or Negative value
GTO 1
RCL 3
RCL 3
2
FRAC
2
x
X=0? // Test n-th term for Even or Odd number
GTO 3
GSB 2 // Odd integer of n-th term
RCL 1
x
RTN
LBL 1 // Common Ratio is Greater than Zero
RCL 2
RCL 3
1
Y^X
RCL 1
x
RTN
LBL 2 // identical routine for common ratio value Less than Zero
RCL 2
RCL 3
1
X<>Y
CHS
X<>Y
Y^X
RTN
LBL 3 // Even integer of n-th term
GSB 2
CHS
RCL 1
x
RTN
Remark:
Procedure:
Example:
a=1
r= -3
n= selected term
Program:
LBL A // Geometric Sequence
ENTER
ENTER
R^
LBL 1
R/S
x
GTO 1
LBL B // n-th term
Rv
Rv
STO 3
Rv
Rv
1
GSB 2
RCL 3
x
RTN
LBL C // Sum to the n-th term
Rv
STO 4
Rv
STO 3
Rv
Rv
GSB 2
1
RCL 3
x
RCL 4
1
RTN
LBL 2
STO 1
X<>Y
STO 2
0
X<>Y
X>Y
GTO 3
CHS
STO 2
RCL 1
2
FRAC
0
X=Y
GTO 3
RCL 2
RCL 1
Y^X
CHS
RTN
LBL 3
RCL 2
RCL 1
Y^X
RTN
Gamo
