Full Version: How best manage VAR?
Using the Equation Library and Solving them will render a lot of VARIABLES stored on the HP 50g.
And they are mixing along with my Variables and Programs, spread across the DIRECTORIES I am using at the time of Solving the equations.
Is there a way to make the Equations create its own Directory under the HOME dir , where the eautions can store their varaibles, so that I can easily delete that DIR using the FILES command?
Or , is there a way to delete all that VARIABLES that were created by the Equations easily?
How do you manage, work around, with all that VAR that are not needed?
Thanks
Alvaro
