Resurrecting this old thread ...
When X = 0+iB, SQRT(X) should have equal real and imaginary parts (apart from the sign).
But that is (still) not the case.
The 48G algorithm I posted gives the correct result - in the 48, with its 3 extra digits, but not in Free42.
Example:
-1E-12
SQRT
SQRT
COMPLEX
equals -1E-37, exactly what you get when you follow the 48G algorithm.
Cheers, Werner
(02-12-2021 02:45 PM)Werner Wrote: [ -> ]When X = 0+iB, SQRT(X) should have equal real and imaginary parts (apart from the sign).
I don't think that is something I ever tested. I implemented your algorithm in 2.0.21 and verified that it gave the desired result for 0+iB when B/2 is a perfect square... I suppose this means an explicit check for Re(X)=0 will be needed after all.
according to the thread, you implemented a specific Re()=0 test?
That's what I was thinking of doing at first, but then you suggested the 48G algorithm, and I implemented that instead. There is no check for pure imaginary.
free42/common/core_commands6.cc
static int mappable_sqrt_c(phloat xre, phloat xim, phloat *yre, phloat *yim) {
if (xre == 0 && xim == 0) {
*yre = 0;
*yim = 0;
return ERR_NONE;
phloat r = hypot(xre, xim);
phloat a = sqrt((r + fabs(xre)) / 2);
phloat b = xim / (a * 2);
if (p_isinf(a)) {
xre /= 100;
xim /= 100;
b = xim / (a * 2);
a *= 10;
b *= 10;
if (xre >= 0) {
*yre = a;
*yim = b;
} else if (b >= 0) {
*yre = b;
*yim = a;
} else {
*yre = -b;
*yim = -a;
return ERR_NONE;
