[[1,5,0,2,5],[1,5,1,0.333333333333,6*i],[1,2,3,8,2*i]]
HOME;
pressing ab/c key rotation gives wrong history(Display) ans but right answer on command line.
I haven't looked at it, but if you mean you see a "list of lists" as the display, this is expected at the moment. We don't have a symbolic matrix object yet for 2D display in home.
Thanks - yep, definitely a display issue here. QPI function output comes out as expected.
[EDIT] Fixed. Was just a missing "return" from the case where there is a complex number, but no complex component (or rather, one of complex component 0). What you are seeing is the "real only" put in, then the complex again right after that appended as well.
