03-14-2018, 10:07 PM
This program can convert numbers to binary quickly by using a lookup table to convert 4 bits at once. Internally, it also uses a fast modulo calculation.
How to use the three programs:
A: Create a lookup table in registers 1 to 15. This takes about 3 minutes.
B: Convert a number to binary. If you created the table this will be fast. Without the table it will be 3x slower.
D: y mod x
The B program reads flag 0: If it is clear it will use a slow algorithm, if it is set it will use the fast one instead. Program A clears flag 0, creates the lookup table and then sets flag 0.
In my custom notation the code looks like this:
However, for entering it into the calculator, the classical button notation might be easier:
If you want to know how I wrote this you can read my blog post about it.
D: y mod x
; create lookup table
A:
flag0 = false ; slow algorithm
15
i=
0: ; for(i = 15, i > 0, i--)
i
int
gosub B ; to binary
register[i]=
decrementSkipEqual
goto 0
flag0 = true
return
; toBinary with lookup table
B:
0 ; the result
register[0]= ; exponent
x >< y
1: ; begin loop
if(x == 0)
goto 4
register[16]= ; store input
if(flag0)
goto 2 ; fast algorithm
;else
; slow algorithm
2
gosub D ; (`mod` 2)
register[0]
10^x
1
register[0] +=
pop
register[16]
2
int
goto 1
; fast (fetch 4 bits using the lookup table)
2:
; fetch 4 bits from input
16
gosub D ; (`mod` 16)
if(x == 0)
goto 3
;else
; lookup binary
i=
pop
register[i]
3:
; shift result bits to the left and add to result
register[0]
10^x
; increment left shift amount for next iteration
4
register[0] +=
pop
; input `shr` 4
register[16]
16
int
goto 1 ; end loop
4:
pop
return
; fast modulo
D:
register[17]=
fractional
register[17]
return
LBL A
CF 0
1
5
STO I
LBL 0
RCL I
GSB B
STO (i)
DSE
GTO 0
SF 0
RTN
LBL B
0
STO 0
x><y
LBL 1
x=0
GTO 4
STO . 6
F? 0
GTO 2
2
GSB D
RCL 0
10^x
1
STO + 0
R\/
RCL . 6
2
int
GTO 1
LBL 2
1
6
GSB D
x=0
GTO 3
STO I
R\/
RCL (i)
LBL 3
RCL 0
10^x
4
STO + 0
R\/
RCL . 6
1
6
int
GTO 1
LBL 4
R\/
RTN
LBL D
STO . 7
FRAC
RCL 17
RTN
