04-03-2014, 01:50 PM
04-03-2014, 02:17 PM
I just tried your simple, definite integral int(x,x,0,3), with emulator in cas view;
in this case, the only thing hung was a nine over a two.
04-03-2014, 05:01 PM
I'm using the physical Prime.
I tried the emulator as well, and if you pay close attention, you will notice a certain lag with this problem. Subsitute other limits, and the response is instantaneous. Go figure.
04-03-2014, 05:41 PM
(04-03-2014 05:01 PM)Helge Gabert Wrote: [ -> ]I'm using the physical Prime.
Using the physical Prime.
If you uncheck the Exact flag in CAS, you get the message:
Adaptive method failure, will try with Romberg, last approximation was 4.5
If you leave the flag set and hit "On" after starting the calculation you get 9/2 instantly.
In Home if you use the Template and input the integral, the calc hangs and pressing On results in
Error: Invalid input, but only if the CAS a Exact flag is set. With the flag clear you get 4.5.
Very strange
Cheers, Terje
04-04-2014, 01:31 AM
It doesn't really "hang".
It takes its sweet time, during which there's an animated hourglass in the top right corner of the screen, indicating activity. After a while, it spits out 9/2.
While on the subject, is there a way to interrupt/cancel a calculation?
04-04-2014, 01:38 AM
Yes, cancel with Esc or ON. Or ON-Symb if ESC or ON don't work.
By the way, the above integral can be computed immediately by hitting the ON key, after pressing ENTER.
04-05-2014, 04:11 AM
(04-04-2014 01:38 AM)Helge Gabert Wrote: [ -> ]By the way, the above integral can be computed immediately by hitting the ON key, after pressing ENTER.
Now *that* is truly bizarre. So it gets the result immediately, but... Decides to pretend it's taking longer?
Quote:James T. Kirk: Mr. Scott. Have you always multiplied your repair estimates by a factor of four?
Montgomery Scott: Certainly, Sir. How else can I keep my reputation as a miracle worker?
04-05-2014, 05:49 PM
Yes, bizarre is the word.
Also, why would other integration limits not present any lag time problems, e.g., int(x,x,-3,0) or int(x,x,0,5) are fine, only integrating x dx between 0 and 3 exhibits this behavior?
04-16-2014, 03:55 PM
FWIW, further analysis shows that this behavior is affected by an upper limit of the form 3*2^(n-1), n=1,2,. . . , i.e., 3, 6, 12, 24, . . . , with a lower limit of 0.
