Hi there,
I enjoy my 41cx, but sometimes wish it was a little bit thinner. I think there are a couple of people on the forum who are skilled at 3d printed parts. So is it possible to redesign the back cover and make 41cx a little bit thinner?
thanks,
(02-26-2018 04:52 PM)atilla457 Wrote: [ -> ]Hi there,
While feasible to make the lower portion a small amount thinner (perhaps 1-2mm as it sits just above the CPU board), the thickness of the upper portion cannot be reduced because of the ports for the 4 x ROM/RAM modules. And since that cannot be reduced, very little would be gained by reducing just the lower section. So a lot of work for very little benefit IMHO.
(02-26-2018 05:57 PM)rprosperi Wrote: [ -> ]the thickness of the upper portion cannot be reduced because of the ports for the 4 x ROM/RAM modules.
Unless you make it a real half-nut with 2 module ports
(02-26-2018 07:02 PM)Didier Lachieze Wrote: [ -> ] (02-26-2018 05:57 PM)rprosperi Wrote: [ -> ]the thickness of the upper portion cannot be reduced because of the ports for the 4 x ROM/RAM modules.
I am so eternally grateful they did not implement that plan.
HÃ¥kan
(02-26-2018 07:02 PM)Didier Lachieze Wrote: [ -> ]Unless you make it a real half-nut with 2 module ports
No! No ports and a Lipo battery. We could get rid of the mid-piece bezel and bottom on a half nut. Direct power onto the main board and get rid of the battery flex circuit...
I just checked my boneyard and have about a half-dozen full nuts in various states of repair but no half nuts.
Shopping we go!
(02-27-2018 04:58 AM)Nate Martin Wrote: [ -> ]I just checked my boneyard and have about a half-dozen full nuts in various states of repair but no half nuts.
Isn't a half-dozen full nuts = a dozen half nuts?
(02-27-2018 07:48 AM)Massimo Gnerucci Wrote: [ -> ] (02-27-2018 04:58 AM)Nate Martin Wrote: [ -> ]I just checked my boneyard and have about a half-dozen full nuts in various states of repair but no half nuts.
Sigh. That's just nuts...
(Post 183)
And what do you store them in, a nut case?
(02-27-2018 04:58 AM)Nate Martin Wrote: [ -> ] (02-26-2018 07:02 PM)Didier Lachieze Wrote: [ -> ]Unless you make it a real half-nut with 2 module ports
No ports? Then you have a DM-41!
