06-03-2018, 08:27 PM
Recently a colleague brought to me a Casio fx-2700P Programmable calculator. It is from approx. 1981.
After installing new batteries and checking that everything worked, I thought I'd try writing a little program for it.
Some interesting features:
Besides the M memory, it has 6 "K" memories addressed with Kin and Kout. They support register arithmetic +, -, รท and *.
It has 2 conditionals x>0 and x<=M both of which if true loop to the first line of the program.
The programming is blind, so programming steps are not visible as you type them in. Just type the sequence and hope for the best (i.e. test with a few known results).
I decided to try a program that calculates the area of a circle or the volume of a sphere given the value of the radius.
Enter the radius as positive for area or negative for volume.
The last 4 steps are only really necessary to re-initialise K memory 2, to make repeat calculations easier.
As the loop is back to the first line of the program, it becomes difficult to have an initialisation part at the beginning of the program, hence the need to manually initialise with "1 Kin 2" before running the program for the first time. Re-initialisation is done at the end the program so that consecutive runs of the program do not need manual initialisation.
Kin 1 Save in K memory 1
Kin*2 Multiply and save in K memory 2
Kout 2 Recall K memory 2
+/- Change sign
Min Save in M
Kout 1 Recall K memory 1
x<=M If true goto first line else goto next
x^2 Square result
sqrt Square root of result (these 2 steps make it positive)
* Multiply
pi with pi
Kin 3 Save in K memory 3
1
Kin 2 Re-initialise K memory 2
Kout 3 Recall K memory 3
Initialise:
1 Kin 2
