For integer decimal input N the programme tests whether N in binary is palindromic.
This is OEIS
https://oeis.org/A178225
CkSum: # C785h
CK1&Dispatch
# FF
FPTR2 ^DupQIsZero?
casedrop
"0"
NULL$SWAP
FPTR2 ^Z>ZH
FPTR2 ^ZBits
ZERO_DO
INDEX@
FPTR2 ^ZBit?
ITE
CHR_1
CHR_0
ROTSWAP
>H$
SWAPLOOP
DROP
DUP'
xSREV
EvalNoCK
EQUAL
COERCEFLAG
A neater, faster programme:
CkSum: # 1FA9h
CK1&Dispatch
# FF
DUP
ZINT 2
Z<
casedrop
%1
FPTR2 ^Z>ZH
FPTR2 ^ZBits
DUP
BINT2
3UNROLL
ZERO_DO
INDEX@
FPTR2 ^ZBit?
SWAP
ISTOP-INDEX
#1-
FPTR2 ^ZBit?
ROT
EQUAL
ITE
OVERINDEX@
?SEMI
%1
ExitAtLOOP
%0
ExitAtLOOP
LOOP
ROTROT2DROP
Here the definitive version of the programme, a model of elegance, shortest & fastest possible.
I'm sure no one can find an improvement - I'd be amazed if you did!
CkSum: # 2C8Eh
CK1&Dispatch
# FF
%1
SWAPDUP
ZINT 2
Z<
caseDROP
FPTR2 ^Z>ZH
FPTR2 ^ZBits
DUPUNROT
BINT2
ZERO_DO
SWAP#1-SWAP
OVER
FPTR2 ^ZBit?
SWAPINDEX@
FPTR2 ^ZBit?
ROT
EQUAL
?SKIP
ROTDROP
%0
3UNROLL
ExitAtLOOP
LOOP
2DROP
Well..
that sounded like a challenge, no? Never could resist.
Two things bothered me about your code:
First, the sequence
While #2/ is not the same, in this case it does the job - there's no need to test the middle bit, so to speak.
Second thing: the snippet
?SKIP
ROTDROP
%0
3UNROLL
ExitAtLOOP
The secondary wastes 5 bytes in my eyes ;-) so I tried to do without one.
It turned out not to be so easy to improve upon, though. All I've been able to manage so far is save a single command (2.5 bytes).
Well, this is it, 97.5 Bytes, # 945Fh
CK1&Dispatch
# FF
DUP
ZINT 2
Z<
casedrop
%1
FPTR2 ^Z>ZH
FPTR2 ^ZBits
DUPUNROT
#2/
DUP
ZERO_DO
DROP
SWAP#1-SWAP
OVER
FPTR2 ^ZBit?
SWAPINDEX@
FPTR2 ^ZBit?
ROT
EQUAL
DUP
?SKIP
ExitAtLOOP
LOOP
UNROT2DROP
COERCEFLAG
Cheers, Werner
Very nice, Werner, congrats!
After incorporating your suggestion not to test the middle bit into my version, my programme tested the 691 decimal digits binary palindrome
8999426634711432210874665907816903956988683664722921509315478192749207880463456922990872105835307171055080251964909961257453802179645499054716333672539545544118932968691884084960688692597413433759874480699854844501836094850133947983753204817698281788633116753054503696404359361578125612931539740671066508864784351529154391934339180653852887403515211867169617043784799543175497949666073579771413066215421083208629713930186272527242260162642480210729326691627240372999886606875669375524245678348406217132838891048302886533496403036545542639162038790659197087400238193942009504229380072518565320107237768892369217461716099224829006631795274618330918728005922738663971483339019497645460273904057
in
3.891345 s
& your programme took
3.869235 s
(average of 20 runs).
So your programme is smaller & faster, I shall put it in my library.
Thus the crestfallen boaster acknowledges your acumen.
Shorter:
CkSum: # 1249h
CK1&Dispatch
# FF
FPTR2 ^DupQIsZero?
casedrop
%1
FPTR2 ^Z>ZH
FPTR2 ^ZBits
DUPUNROT
#2/
DUP
ZERO_DO
DROP
SWAP#1-SWAP
OVER
FPTR2 ^ZBit?
SWAPINDEX@
FPTR2 ^ZBit?
ROT
EQUAL
DUP
?SKIP
ExitAtLOOP
LOOP
ROTROT2DROP
COERCEFLAG
Shorter:
NB PTR 273B6 has been stable at least from version 1.19-6 on.
CkSum: # FB5Bd (edited to correct incorrect checksum)
CK1&Dispatch
# FF
PTR 273B6
FPTR2 ^ZNMax
FPTR2 ^Z>ZH
FPTR2 ^ZBits
DUPUNROT
#2/
DUP
ZERO_DO
DROP
SWAP#1-SWAP
OVER
FPTR2 ^ZBit?
SWAPINDEX@
FPTR2 ^ZBit?
ROT
EQUAL
DUP
?SKIP
ExitAtLOOP
LOOP
ROTROT2DROP
COERCEFLAG
But what does it do, PTR 273B6?
Werner
It puts the short form of
ZINT 1
on the stack.
In that case, add
EQU ZINT_1 $273B6
as first line of your source code, then you can use ZINT_1. A bit clearer than PTR 273B6 ;-)
Werner
In my own programming environment I use an XTable library where
Z1_
represents the pointer.
As not everyone has the same XTable library I avoid using Z1_ publicly, preferring to use the pointer, which should compile OK for everyone.
Your suggestion is a good idea, I mean more transparent, but could well confuse those not so experienced in Sys programming.
"but could well confuse those not so experienced in Sys programming"
? More confused than by PTR 273B6?
Werner
