Full Version: 42s style SOLVER for 41 with Advantage Module
I found this 42s style solver program HP41SOLVR in the HP-41C software library. Does anyone know of a similar 42s style solver program that uses the SOLVE features of the HP-41 Advantage module?
(02-20-2018 05:02 AM)Craig Bladow Wrote: [ -> ]I found this 42s style solver program HP41SOLVR in the HP-41C software library. Does anyone know of a similar 42s style solver program that uses the SOLVE features of the HP-41 Advantage module?
Yes, you may check the Equation library included in the "Interchangeable Solutions ROM". It's based on an enhanced version of the program you referenced, and includes a set of basic equations as examples.
Manual and Module
The manual is also posted on the CL site, although with a different title: (scroll page down to the middle)
Integrated Solutions Manual
Cheers,
ÁM
Thanks for the links. That program does not appear to depend on the SOLVE program in the Advantage module, which is what I am looking for.
(02-21-2018 03:21 AM)Craig Bladow Wrote: [ -> ]Thanks for the links. That program does not appear to depend on the SOLVE program in the Advantage module, which is what I am looking for.
But it does, it's only that the name used is "FROOT" - the equivalent to SOLVE in the SandMath module. You can use SOLVE and the Advantage instead, as they are 100% equivalent.
ÁM.
