02-11-2018, 09:18 PM
Hello, Sorry for my bad translation
A good practice of computer programming is divide and conquer (Folders, subfunctions, etc), which is disseminated in most programming books.
The system of the hp-prime allows to call from directory or folder, a identifier or function and works very well =), except that if the file name (pc-name) is renamed it fails =(
Example of the use of the dot operator or double colon, binary files below
Step 1: create a file with the following name
file: dir_pi_main.hpprgm (main file, library)
step 2: Execute the following instruction.
dir_pi_main.main_pi_k() [ENTER] // recall the variable pi_k of dir_pi_main
returns {3.14159265359} // ok
or
[tools] program functions dir_pi_main main_pi_k [ok]
dir_pi_main.main_pi_k() [ENTER] {3.14159265359}
Step 3: create a file with the following name
file: dir_pi_2.hpprgm
step 4: Execute the following four instructions.
dir_pi_2.main_pi_k() [ENTER] returns {3.14159265359} // ok
pi_ext1() [ENTER] returns {4.14159265359} // ok
pi_ext2 ()[ENTER] returns {6.14159265359} // ok
pi_ext3 ()[ENTER] returns {6.14159265359} // ok
Step 5: create a file with the following name
file: dir_pi_3.hpprgm
step 6: Execute the following three instructions.
dir_pi_3.main_pi_k() [ENTER] returns {2.14159265359, 6.14159265359} // ok
pi_ext4 ()[ENTER] returns {1.14159265359, 9.14159265359} // ok
pi_ext5() [ENTER] returns {1.14159265359, 9.14159265359} // ok
Problem #1: If you rename the main file, many functions would fail, because they do not find the correct path
One solution is to store in the header a folder name in each file (internal library name), in this way the name of the file is irrelevant (external library name [pc name]), the real path is defined by the header (internal library name)
With the new directive
file: dir_pi_main.hpppl
file: dir_pi_2.hpppl
file: dir_pi_3.hpppl
you can check the problem by downloading the files below twice and sending the second download to the HPCONNECTITYKIT and you will notice that a syntax error is generated because it does not include the path, since a postfix (n) to the file is appended
2: second problem
In the memory manager, the variables can be reset to zero, but this alters the constant value defined within the algorithm, which produces unexpected results, for this reason to avoid this problem, a possible solution is to define a global variable as constant
CONSTANT EXPORT qpiDIGITS
Example for test the second problem, binary files below (QPI_4.4.hpprgm)
You can check it yourself, resetting the variables qpiEXPLN, qpiMAXINT, qpiDIGITS of QPI_4.4.hpprgm
QPI_(1.41421356237) [enter] returns sqrt(2)
[shift]+[tools]: user vars: qpiEXPLN (real), qpiMAXINT (real), qpiDIGITS (real) then reset each
QPI_(1.41421356237) [enter] returns 1 (failure)
please test the codes and tell me
Thanks
Jaime
PHP Code:
export pi_k:=π; // declares a visible global variable pi_k=3.14159265359 path dir_pi_main::pi_k
EXPORT main_pi_k()
return {pi_k}; // returns the internal variable pi_k, path dir_pi_main::pi_k
or
PHP Code:
EXPORT main_pi_k()
return { dir_pi_main.pi_k }; // returns a external variable (pi_k of dir_pi_main)
EXPORT pi_ext1()
dir_pi_main.pi_k:=dir_pi_main.pi_k+1; // modify an external variable (pi_k of dir_pi_main) where pi_k = pi_k+1
return { dir_pi_main.pi_k } ; // returns an external variable
EXPORT pi_ext2()
dir_pi_main.pi_k:=dir_pi_main.pi_k+2; // modify an external variable (pi_k of dir_pi_main) where pi_k = pi_k+2
EXPORT pi_ext3()
PHP Code:
export pi_k=pi-1; // declares a visible variable pi_k=3.14159265359-1 path dir_pi_3::pi_k
EXPORT main_pi_k()
return( { pi_k, dir_pi_main.pi_k } ); // returns a internal (path dir_pi_3::pi_k) and external variable (path dir_pi_main::pi_k)
EXPORT pi_ext4()
pi_k:=pi_k-1; // modify an internal variable (pi_k of dir_pi_3) where pi_k = pi_k-1
dir_pi_main.pi_k:=dir_pi_main.pi_k+3; // modify an external variable (pi_k of dir_pi_main) where pi_k = pi_k+3
return( { pi_k, dir_pi_main.pi_k } ); // returns a internal and external variable
EXPORT pi_ext5()
PHP Code:
#FOLDER dir_pi_main // header for real path
export pi_k:=pi;
EXPORT main_pi_k()
return {pi_k};
PHP Code:
#FOLDER dir_pi_2 // header
EXPORT main_pi_k()
PHP Code:
#FOLDER dir_pi_3 // header
export pi_k=pi-1;
2: second problem
PHP Code:
export qpiEXPLN:=100; // max denom for exp(p/q) or ln(p/q)
export qpiMAXINT:=2^20; // largest n allowed for sqrt(n)=a*sqrt(b)
export qpiDIGITS:=10; // controls accuracy (best results at 9 or 10)
Thanks
Jaime
