02-10-2018, 04:04 PM
Dynamic Menu
0.Abstract
This routine will show a menu defined by the first column of a matrix, with
automatic paging. The matrix may have one or more columns.
1.Usage
In:
.matrix indexed or edited, IJ pointing within the page to show.
A: message to show with menu. If alpha reg is clear, no AVIEW will be done.
The message may be at most 24 characters.
Out:
- when pressing a menu button:
matrix indexes IJ at selected element
X: whatever was entered before pressing the menu button
- when pressing EXIT:
F25 Set
2.Routine details
The menu will be made up of 'pages' of 6 items each. The entry indexes IJ
will be repositioned to the start of a page before building the menu.
The up/down arrows will only be defined when the matrix has more than 6 entries.
When indexing or editing a matrix, the indexes IJ will be both 1.
This routine does not use variables.
For an example of how to use it, see the Conversion program posted right after this one.
3.Commented Listing
The raw file is also attached.
Cheers, Werner
0.Abstract
1.Usage
In:
Out:
F25 Set
2.Routine details
3.Commented Listing
{ 209-Byte Prgm }
>LBL "DMENU"
>LBL 12
XEQ 13 -- set IJ to first entry in page
>LBL 11 -- IJ in YX
CLMENU
X!=Y? -- when this is not the first page, show up/down keys
XEQ 78
ASTO ST Z -- save message
ASHF
ASTO ST Y
ASHF
ASTO ST X
ASHF
ASTO ST L
KEY 9 GTO 09 -- build menu page
XEQ 14 -- CLA RCLEL ARCL ST X Rv I+
KEY 1 GTO 01
FS? 76
GTO 00
XEQ 14
KEY 2 GTO 02
FS? 76
GTO 00
XEQ 14
KEY 3 GTO 03
FS? 76
GTO 00
XEQ 14
KEY 4 GTO 04
FS? 76
GTO 00
XEQ 14
KEY 5 GTO 05
FS? 76
GTO 00
XEQ 14
KEY 6 GTO 06
FC? 76
XEQ 78 -- handles the case where it is the first page, and there are more
>LBL 00
I- -- get back to the correct page. F76 state is preserved!
CLA -- rebuild message
ARCL ST Z
ARCL ST Y
ARCL ST X
ARCL ST L
XEQ 13 -- set indexes back to first entry in page
>LBL 10
ALENG
X>0?
AVIEW
MENU
STOP
GTO 10
>LBL 06
I+
>LBL 05
I+
>LBL 04
I+
>LBL 03
I+
>LBL 02
I+
>LBL 01
CF 25
RTN
>LBL 07 -- previous page
I-
GTO 12
>LBL 08 -- next page
RCLIJ
CLX
6
FS? 76
SIGN
1
STOIJ
GTO 11
>LBL 09
SF 25
RTN
>LBL 13
RCLIJ
SIGN
RCL ST X
6
MOD
1
STO+ ST Y
STOIJ
RTN
>LBL 14
CLA
RCLEL
ARCL ST X
Rv
I+
RTN
>LBL 78
KEY 7 GTO 07
KEY 8 GTO 08
END
Cheers, Werner
