01-31-2018, 05:03 PM
(01-31-2018 04:37 PM)TheKaneB Wrote: [ -> ]There's also the Black-Scholes formula for option pricing, not found on the 12C.
not found in the Calc, but there is in its manual...
(01-31-2018 05:09 PM)Tim Wessman Wrote: [ -> ]I was going to wait to post anything until the "update.xml" file that drives the automatic detection of updates was posted. Apparently, the old one was pulled down by the system and then the system proceeded to re-upload with a new date..... dunno. :?
The document updates are still pending as well.
(01-31-2018 10:33 AM)ggauny@live.fr Wrote: [ -> ]Hi,
To load you can take a look at TiPlanet.org, a french site from where you can
download.
https://tiplanet.org/forum/portal.php?&s...052789911e
(01-31-2018 05:34 PM)smp Wrote: [ -> ][quote='ggauny@live.fr' pid='90083' dateline='1517394836']
What irony to have to get a very important HP calculator update through TIPlanet!
smp
(01-31-2018 07:24 PM)Guenter Schink Wrote: [ -> ][*]APPMe too. Also on virtual calculator.
[*]Geometry
[*]Symb
[*]New
[*]OK
Calculator restarts. Someone else with the same experience?
(01-31-2018 08:03 PM)Voldemar Wrote: [ -> ]Me too. Also on virtual calculator.
(01-31-2018 08:03 PM)Voldemar Wrote: [ -> ]Not having real calculator, but my Virtual one inserts 'undef' into edited field.(01-31-2018 07:24 PM)Guenter Schink Wrote: [ -> ][*]APPMe too. Also on virtual calculator.
[*]Geometry
[*]Symb
[*]New
[*]OK
(01-31-2018 08:10 PM)salvomic Wrote: [ -> ](01-31-2018 08:03 PM)Voldemar Wrote: [ -> ]Me too. Also on virtual calculator.
I cannot reproduce: in Geometry have already some curves, Symb -> in a void field New then OK I get "undef" in the field (then it is apparently not easy to delete it) but no restart, both HC and VC.
Are you start with a void Symb list or there are already items?
Salvo
(01-31-2018 08:11 PM)chromos Wrote: [ -> ]my Virtual one inserts 'undef' into edited field.Tried again. Yes, inserts «undef». First time was application error and application closed.
(01-31-2018 08:22 PM)Guenter Schink Wrote: [ -> ]Ok. I had started with an empty list, and it crashed. Now after I have entered an item it doesn't do that any longer. Now I can't reproduce this behaviour.
Günter
(01-31-2018 08:32 PM)salvomic Wrote: [ -> ](01-31-2018 08:22 PM)Guenter Schink Wrote: [ -> ]Ok. I had started with an empty list, and it crashed. Now after I have entered an item it doesn't do that any longer. Now I can't reproduce this behaviour.
Günter
so it could be a bug related at the starting with an empty list...
(01-31-2018 09:18 PM)Guenter Schink Wrote: [ -> ]Yes, definitely. Now I was able to reproduce the behaviour. On both, the virtual and the real calculator.
- Reset
- App
- Geometry
- Symb
- New
- OK
Real calculator restarts, virtual calculator shuts down, showing a Windows error message.
Günter
(01-31-2018 05:58 PM)Tim Wessman Wrote: [ -> ]The fact that Prime is either the #1 or #2 recommend calculator for France and has a high level of interest on the main european TI site speaks rather highly in my mind...
(02-01-2018 07:29 PM)striegel Wrote: [ -> ]Since I haven't had the Prime for very long, I'm a relatively naive user of the Connectivity Kit. When I first acquired the Prime last last year, I updated the firmware using the Conn Kit.
Now when I tell it to update firmware, it shows the same version it already has:
"Update firmware: 20170710"
I did download the .zip file via ftp, but how does the Conn Kit make use of this?
Alan
(02-01-2018 07:29 PM)striegel Wrote: [ -> ]Now when I tell it to update firmware, it shows the same version it already has:There is «HP Connective Kit» folder in Documents folder. There is «Firmware» folder. Delete all from «Firmware» folder. Unzip «HP_Prime_Calculator_Firmware_20180124» (13 files) to «Firmware» folder. Now You can update calculator to the latest firmware.
