This is a collection of the 55 programs in the HP-25 Applications Programs manual, suitable for loading into the Teenix MultiCalculator emulator, hardware calculator, or the Classic upgrade board.
In the attached ZIP file you'll find all 55 programs organized into two library directories for easy import into a hardware calculator memory block of 32 program locations. There are also two Excel files and their PDF output, one in US Letter format and the other in A4 format. These sheets identify which file has which program, and where each program is loaded into a block and memory location. The sheets are also useful in keeping track of other programs you have loaded into your hardware calculator. See the attached PDF file for details.
Each program was entered and tested in the emulator. They have also been loaded into a Harald & Tony Classic upgrade board and spot checked. I do not have the equipment to test the A4 format sheet and PDF for proper printing.
Enjoy!
~Mark
3-February-2018. I've updated the attached ZIP file to include the listings for each of the individual programs. The Teenix emulator has a program editor that allows you to edit a program in memory as text, and to save that program as a text file. Comments can be added to the file following two slash characters, i.e. '// comment' The listings help identify each program by placing the program title as an opening comment. They also served to validate correct entry of each program from the HP manual.
(01-28-2018 10:09 PM)mfleming Wrote: [ -> ]This is a collection of the 55 programs in the HP-25 Applications Programs manual, suitable for loading into the Teenix MultiCalculator emulator, hardware calculator, or the Classic upgrade board.
Enjoy!
~Mark
Hi Mark,
Awesome and a lot of work no doubt. Can I post them on the teenix site?
cheers
Tony
I've updated the ZIP file in the original post to include the listings for each individual program. The Teenix emulator has a program editor that you can use to edit a program and to save that program as a text file. Comments can be added to the file following two slash characters, i.e. '// comment'
The listings help identify each program by placing the program title as an opening comment. They also served as a check on correct entry of each program from the HP manual.
~Mark
The chapter
Emulator Card File Format in the
Notes on HP’s Classic Calculators allowed me to decode the
*.pgf files and translate them into a format that can be used in this
HP-25C emulator.
Enjoy and have fun.
Example
Programs/Library1/HP25-AP06.25:
01: 23 01 : STO 1
02: 24 00 : RCL 0
03: 31 : ENTER
04: 31 : ENTER
05: 31 : ENTER
06: 24 01 : RCL 1
07: 74 : R/S
08: 23 01 : STO 1
09: 34 : CLx
10: 51 : +
11: 61 : *
12: 24 01 : RCL 1
13: 51 : +
14: 13 07 : GTO 07
15: 24 00 : RCL 0
16: 15 22 : g 1/x
17: 23 02 : STO 2
18: 23 03 : STO 3
19: 61 : *
20: 74 : R/S
21: 24 02 : RCL 2
22: 24 03 : RCL 3
23: 61 : *
24: 23 03 : STO 3
25: 61 : *
26: 51 : +
27: 13 20 : GTO 20
28: 13 00 : GTO 00
29: 13 00 : GTO 00
30: 13 00 : GTO 00
31: 13 00 : GTO 00
32: 13 00 : GTO 00
33: 13 00 : GTO 00
34: 13 00 : GTO 00
35: 13 00 : GTO 00
36: 13 00 : GTO 00
37: 13 00 : GTO 00
38: 13 00 : GTO 00
39: 13 00 : GTO 00
40: 13 00 : GTO 00
41: 13 00 : GTO 00
42: 13 00 : GTO 00
43: 13 00 : GTO 00
44: 13 00 : GTO 00
45: 13 00 : GTO 00
46: 13 00 : GTO 00
47: 13 00 : GTO 00
48: 13 00 : GTO 00
49: 13 00 : GTO 00
Contents
attachment=10877]
Archive: hp-25-applications-programs.zip
Length Date Time Name
1017 07-16-2022 17:39 Programs/Library1/HP25-AP01.25
1002 07-16-2022 17:39 Programs/Library1/HP25-AP02.25
1019 07-16-2022 17:39 Programs/Library1/HP25-AP03.25
1044 07-16-2022 17:39 Programs/Library1/HP25-AP04.25
1012 07-16-2022 17:39 Programs/Library1/HP25-AP05.25
1019 07-16-2022 17:39 Programs/Library1/HP25-AP06.25
1010 07-16-2022 17:39 Programs/Library1/HP25-AP07.25
1015 07-16-2022 17:39 Programs/Library1/HP25-AP08.25
1051 07-16-2022 17:39 Programs/Library1/HP25-AP09.25
1006 07-16-2022 17:39 Programs/Library1/HP25-AP10.25
928 07-16-2022 17:39 Programs/Library1/HP25-AP11.25
955 07-16-2022 17:39 Programs/Library1/HP25-AP12.25
954 07-16-2022 17:39 Programs/Library1/HP25-AP13.25
961 07-16-2022 17:39 Programs/Library1/HP25-AP14.25
950 07-16-2022 17:39 Programs/Library1/HP25-AP15.25
1024 07-16-2022 17:39 Programs/Library1/HP25-AP16.25
902 07-16-2022 17:39 Programs/Library1/HP25-AP17.25
982 07-16-2022 17:39 Programs/Library1/HP25-AP18.25
1001 07-16-2022 17:39 Programs/Library1/HP25-AP19.25
986 07-16-2022 17:39 Programs/Library1/HP25-AP20.25
1033 07-16-2022 17:39 Programs/Library1/HP25-AP21.25
954 07-16-2022 17:39 Programs/Library1/HP25-AP22.25
986 07-16-2022 17:39 Programs/Library1/HP25-AP23.25
969 07-16-2022 17:39 Programs/Library1/HP25-AP24.25
1007 07-16-2022 17:39 Programs/Library1/HP25-AP25.25
992 07-16-2022 17:39 Programs/Library1/HP25-AP26.25
995 07-16-2022 17:39 Programs/Library1/HP25-AP27.25
1035 07-16-2022 17:39 Programs/Library1/HP25-AP28.25
973 07-16-2022 17:39 Programs/Library1/HP25-AP29.25
970 07-16-2022 17:39 Programs/Library1/HP25-AP30.25
971 07-16-2022 17:39 Programs/Library1/HP25-AP31.25
968 07-16-2022 17:39 Programs/Library1/HP25-AP32.25
996 07-16-2022 17:39 Programs/Library2/HP25-AP33.25
960 07-16-2022 17:39 Programs/Library2/HP25-AP34.25
959 07-16-2022 17:39 Programs/Library2/HP25-AP35.25
989 07-16-2022 17:39 Programs/Library2/HP25-AP36.25
1060 07-16-2022 17:39 Programs/Library2/HP25-AP37.25
986 07-16-2022 17:39 Programs/Library2/HP25-AP38.25
1019 07-16-2022 17:39 Programs/Library2/HP25-AP39.25
1063 07-16-2022 17:39 Programs/Library2/HP25-AP40.25
1020 07-16-2022 17:39 Programs/Library2/HP25-AP41.25
1045 07-16-2022 17:39 Programs/Library2/HP25-AP42.25
978 07-16-2022 17:39 Programs/Library2/HP25-AP43.25
1043 07-16-2022 17:39 Programs/Library2/HP25-AP44.25
981 07-16-2022 17:39 Programs/Library2/HP25-AP45.25
987 07-16-2022 17:39 Programs/Library2/HP25-AP46.25
978 07-16-2022 17:39 Programs/Library2/HP25-AP47.25
1033 07-16-2022 17:39 Programs/Library2/HP25-AP48.25
978 07-16-2022 17:39 Programs/Library2/HP25-AP49.25
958 07-16-2022 17:39 Programs/Library2/HP25-AP50.25
992 07-16-2022 17:39 Programs/Library2/HP25-AP51.25
973 07-16-2022 17:39 Programs/Library2/HP25-AP52.25
979 07-16-2022 17:39 Programs/Library2/HP25-AP53.25
1023 07-16-2022 17:39 Programs/Library2/HP25-AP54.25
987 07-16-2022 17:39 Programs/Library2/HP25-AP55.25
54678 55 files
attachment=10878]
Archive: hp-25-ppc.zip
993 07-16-2022 17:19 ppc/HP25_BattleShip.25
1017 07-16-2022 17:19 ppc/HP25_BuffonsNeedle.25
1031 07-16-2022 17:19 ppc/HP25_E2X_1.25
1038 07-16-2022 17:19 ppc/HP25_E2X_2.25
1035 07-16-2022 17:19 ppc/HP25_E2X_3.25
1052 07-16-2022 17:19 ppc/HP25_E2X_4.25
978 07-16-2022 17:19 ppc/HP25_Hexagrams.25
1056 07-16-2022 17:19 ppc/HP25_L1.25
918 07-16-2022 17:19 ppc/HP25_L10.25
973 07-16-2022 17:19 ppc/HP25_L11.25
985 07-16-2022 17:19 ppc/HP25_L12.25
1014 07-16-2022 17:19 ppc/HP25_L13.25
973 07-16-2022 17:19 ppc/HP25_L14.25
1019 07-16-2022 17:19 ppc/HP25_L15.25
1042 07-16-2022 17:19 ppc/HP25_L16.25
1053 07-16-2022 17:19 ppc/HP25_L17.25
1049 07-16-2022 17:19 ppc/HP25_L18.25
1003 07-16-2022 17:19 ppc/HP25_L19.25
1029 07-16-2022 17:19 ppc/HP25_L2.25
1018 07-16-2022 17:19 ppc/HP25_L20.25
1032 07-16-2022 17:19 ppc/HP25_L21.25
971 07-16-2022 17:19 ppc/HP25_L22.25
1013 07-16-2022 17:19 ppc/HP25_L23.25
1002 07-16-2022 17:19 ppc/HP25_L24.25
1008 07-16-2022 17:19 ppc/HP25_L25.25
988 07-16-2022 17:19 ppc/HP25_L26.25
988 07-16-2022 17:19 ppc/HP25_L27.25
1016 07-16-2022 17:19 ppc/HP25_L28.25
1002 07-16-2022 17:19 ppc/HP25_L29.25
988 07-16-2022 17:19 ppc/HP25_L3.25
938 07-16-2022 17:19 ppc/HP25_L31.25
999 07-16-2022 17:19 ppc/HP25_L32.25
1019 07-16-2022 17:19 ppc/HP25_L33.25
999 07-16-2022 17:19 ppc/HP25_L34.25
992 07-16-2022 17:19 ppc/HP25_L35.25
1026 07-16-2022 17:19 ppc/HP25_L36.25
1006 07-16-2022 17:19 ppc/HP25_L37.25
1019 07-16-2022 17:19 ppc/HP25_L38.25
997 07-16-2022 17:19 ppc/HP25_L39.25
969 07-16-2022 17:19 ppc/HP25_L4.25
1037 07-16-2022 17:19 ppc/HP25_L40.25
1040 07-16-2022 17:19 ppc/HP25_L41.25
1033 07-16-2022 17:19 ppc/HP25_L42.25
1001 07-16-2022 17:19 ppc/HP25_L43.25
1048 07-16-2022 17:19 ppc/HP25_L44.25
998 07-16-2022 17:19 ppc/HP25_L45.25
1023 07-16-2022 17:19 ppc/HP25_L46.25
989 07-16-2022 17:19 ppc/HP25_L47.25
1014 07-16-2022 17:19 ppc/HP25_L48.25
1009 07-16-2022 17:19 ppc/HP25_L49.25
980 07-16-2022 17:19 ppc/HP25_L5.25
1025 07-16-2022 17:19 ppc/HP25_L50.25
1003 07-16-2022 17:19 ppc/HP25_L51.25
969 07-16-2022 17:19 ppc/HP25_L52.25
989 07-16-2022 17:19 ppc/HP25_L53.25
1031 07-16-2022 17:19 ppc/HP25_L54.25
1016 07-16-2022 17:19 ppc/HP25_L55.25
1041 07-16-2022 17:19 ppc/HP25_L56.25
997 07-16-2022 17:19 ppc/HP25_L6.25
1030 07-16-2022 17:19 ppc/HP25_L7.25
995 07-16-2022 17:19 ppc/HP25_L8.25
1015 07-16-2022 17:19 ppc/HP25_L9.25
1057 07-16-2022 17:19 ppc/HP25_MasterMind.25
63588 63 files
References
