Hello I have updated my HP41CL with the latest rom set posted on Monte's webpage and I have upgraded the PWRX rom to the latest 22 january version and now the secure/Xpass function won't work, it beeps and does not allow to enter the password, can you check if there is a bug in the last version? I plug the module from RAM, and in previous versions it worked fine.
Regards.
(01-28-2018 10:52 AM)suhast Wrote: [ -> ]Hello I have updated my HP41CL with the latest rom set posted on Monte's webpage and I have upgraded the PWRX rom to the latest 22 january version and now the secure/Xpass function won't work, it beeps and does not allow to enter the password, can you check if there is a bug in the last version? I plug the module from RAM, and in previous versions it worked fine.
Regards.
Thanks for posting. I was going to update my CL later today, but I will hold off until hearing about this, and possibly an update to PWRX if needed.
(01-28-2018 05:28 PM)rprosperi Wrote: [ -> ] (01-28-2018 10:52 AM)suhast Wrote: [ -> ]Hello I have updated my HP41CL with the latest rom set posted on Monte's webpage and I have upgraded the PWRX rom to the latest 22 january version and now the secure/Xpass function won't work, it beeps and does not allow to enter the password, can you check if there is a bug in the last version? I plug the module from RAM, and in previous versions it worked fine.
Regards.
Maybe if someone could confirm this bug/contact Angel for a fix?
Is there any manual with the latest version fixes or changes?
Regards.
(01-28-2018 05:34 PM)suhast Wrote: [ -> ]Maybe if someone could confirm this bug/contact Angel for a fix?
Regards.
When Angel is free, he'll be checking here; probably within a day or two.
The BAUD and TURBO menus dont work also, when I try using the commands in those menus it displays “no YFNX” although I have the yfnx installed
Both issues have been fixed and are available on the CL library as of February 2018.
