01-25-2018, 09:09 AM
01-25-2018, 09:26 AM
You can use the app Solve, then (in Symb) write the equations in E1 and E2; in Num give some guess tries for X and Y and press Solve:
X=9, Y=-4
Salvo
X=9, Y=-4
Salvo
01-25-2018, 10:20 AM
Not to forget the Linear Solver App, you simply enter your 6 numbers and push Solve.
Arno
Arno
01-25-2018, 10:48 AM
(01-25-2018 10:20 AM)Arno K Wrote: [ -> ]Not to forget the Linear Solver App, you simply enter your 6 numbers and push Solve.
Arno
Right, yes!
01-25-2018, 10:58 AM
You could use a graphical approach, using the Advanced Graphing App. The two solutions show up nicely at the intersections of the two expressions:
Points (X,Y) = (4,9) and (9,-4)
[attachment=5592]
-Dale-
[attachment=5592]
-Dale-
01-25-2018, 11:12 AM
01-25-2018, 11:25 AM
(01-25-2018 11:12 AM)Arno K Wrote: [ -> ]No, I was wrong, did not enlarge that pic, so I did not see that the second equation is quadratic.
Arno
and I was wrong two times, then, replying too soon
ok, the second equation is not linear...
01-26-2018, 08:41 AM
solve({13*x+5*y=97,x^2+y^2=97},{x,y})
