03-29-2014, 09:49 PM
Here is a fairly straightforward brainteaser that I hope you find useful for trying out the features and Apps on the HP Prime. I'm not so interested in exact answers, but more-so how you used the Prime to get you there. I have found some ways to explore this numerically, algebraically and graphically - along with a few dead ends.
Information
Colonel Sanders needs to hit two targets at exactly the same time which are located on a hill almost 1km from his camp. He is down to one cannon and one aircraft, each with only one shell/bomb.
Cannon: Has one shell with a fixed 1000m max range and is located at fixed location (0,0)
Aircraft: Flying steady and level at 80m/s, 900m altitude and can drop one bomb
Targets: Two located at (range,elevation) of (700m,100m) and (900,100m)
Diagram Diagram...
Assume no air resistance and that the aircraft flys anyhow .
Question
Using the HP Prime, describe how the aircraft and cannon can be used to hit the two targets at exactly the same time.
Best,
Carl
Information
Diagram Diagram...
Question
Best,
Carl
