Riemann's Zeta Function update (HP-28S, HP-48G/GX/G+, HP-49G/G+/50g) Message #1 Posted by Gerson W. Barbosa on 30 June 2013, 1:01 a.m.
These are updated versions of the Riemann's Zeta function implementations on the 28 and 48 series RPL calculators described in some recent threads. The HP 50g version, which hasn't undergone any significant change is presented here as a reference. The complex gamma function program for both the HP-28S and HP-48G/GX now uses the Lanczos approximation. The results obtained on these calculators are now very close to those obtained on the hp 50g, for all real and complex arguments.
HP-28S
Zeta:
RCLF 57 SF 58 SF
36 CF 59 CF SWAP 1
CF DUP RE 0 <
IF
THEN 1 SF NEG 1 +
END DUP 1 - INV
OVER NEG 10 8 0 s
p q n m b
0 1 n 1 -
FOR k k q ^ +
NEXT n 1 s - ^ s
1 - / + n q ^ 2 / +
BNL 1 2 m
FOR i s i + 3 -
DUP SQ + p * 'p' STO
GETI p * n 1 i - s -
^ * i FACT / b + 'b'
STO 2
STEP b ROT ROT
DROP2 + 1 FS?
IF
THEN 1 CF RAD 1
s - DUP 2 / * SIN
OVER DUP IM NOT
RE DUP 2 MOD
NOT NOT * SIGN NEG *
DROP
IFTE 2 ROT ^
* * s DUP Gamma
ROT NEG ^ * *
END
SWAP STOF
Gamma:
0 { 76.1800917295
-86.5053203294
24.0140982408
-1.23173957245
1.20865097387E-3
-5.39523938495E-6 }
1 6
FOR i DUP i GET 4
PICK i + / ROT +
SWAP
NEXT DROP
1.00000000019 + OVER
/ 2 * * SWAP 5.5
+ DUP LN OVER 5 - *
SWAP - EXP *
BNL:
{ .166666666667
-3.33333333333E-2
2.38095238095E-2
-3.33333333333E-2
7.57575757576E-2
-.253113553114
1.16666666667
-7.09215686275
54.9711779449
-529.124242424 }
: pi
: sqrt
HP-48G/GX/G+
Zeta:
%%HP: T(3)A(D)F(.);
\<< RCLF { -2 -20 -21
-22 } SF SWAP 1 CF
DUP RE 0 <
IF
THEN 1 SF NEG 1 +
END DUP 1 - INV
OVER NEG 10 8 0 \-> s
p q n m b
\<< 0 1 n 1 -
FOR k k q ^ +
NEXT n 1 s - ^
s 1 - / + n q ^ 2 /
+ BNL 1 2 m
FOR i s i + 3 -
DUP SQ + 'p' STO*
GETI p * n 1 i - s
- ^ * i ! / 'b'
STO+ 2
STEP b ROT ROT
DROP2 + 1 FS?
IF
THEN 1 CF RAD 1
s - DUP 2 / \pi * SIN
OVER DUP IM NOT
\<< RE DUP 2
MOD NOT NOT * SIGN
NEG *
\<< DROP
\>> IFTE 2 ROT
^ * * s DUP Gamma \pi
ROT NEG ^ * *
END
\>> SWAP STOF
Gamma:
%%HP: T(3)A(D)F(.);
\<< 0 { 76.1800917295
-86.5053203294
24.0140982408
-1.23173957245
1.20865097387E-3
-5.39523938495E-6 }
1
\<< 3 PICK NSUB + /
\>> DOSUBS
1.00000000019 +
OVER / 2 \pi * \v/ *
SWAP 5.5 + DUP LN
OVER 5 - * SWAP -
EXP *
BNL:
%%HP: T(3)A(D)F(.);
{ .166666666667
-3.33333333333E-2
2.38095238095E-2
-3.33333333333E-2
7.57575757576E-2
-.253113553114
1.16666666667
-7.09215686275
54.9711779449
-529.124242424 }
HP-49G/G+/50g
Zeta:
%%HP: T(3)A(D)F(.);
\<< RCLF { -2. -20. -21. -22. -105. } SF SWAP 1. CF DUP RE 0. <
IF
THEN 1. SF NEG 1. +
END DUP 1. - INV OVER NEG 10. 8. 0. \-> s p q n m b
\<< 0. 1. n 1. -
FOR k k q ^ +
NEXT n 1. s - ^ s 1. - / + n q ^ 2. / + BNL 1. 2. m
FOR i s i + 3. - DUP 1. + * 'p' STO* GETI p * n 1. i - s - ^ * i ! / 'b' STO+ 2.
STEP b NIP NIP + 1. FS?
IF
THEN 1. CF RAD 1. s - DUP 2. / \pi * SIN OVER DUP IM NOT
\<< RE DUP 2. MOD NOT NOT * SIGN NEG *
\<< DROP
\>> IFTE 2. ROT ^ * * s DUP GAMMA \pi ROT NEG ^ * *
END
\>> SWAP STOF
BNL:
%%HP: T(3)A(D)F(.);
{ .166666666667 -3.33333333333E-2 2.38095238095E-2 -3.33333333333E-2
7.57575757576E-2 -.253113553114 1.16666666667 -7.09215686275 54.9711779449
-529.124242424 6192.12318841 -86580.2531136 1425517.16667 -27298231.0678
601580873.901 -15116315767.1 429614643062. -1.37116552051E13 4.88332318973E14
-1.92965793419E16 8.41693047575E17 -4.03380718541E19 2.11507486381E21
-1.20866265223E23 7.50086674608E24 }
BNLG:
%%HP: T(3)A(D)F(.);
\<< { } 2. 50.
FOR n n IBERNOULLI \->NUM + 2.
STEP 'BNL' STO
