HP Forum Archive 18
HP-35S programming
Message #1 Posted by Antonio Maschio (Italy) on 8 Aug 2008, 4:42 a.m.
I'm asking something that I'm not sure it's possible.
Suppose I have FIX 4 as default on my machine, varying format from time to time (FIX 2, SCI 9, STD, FIX 4 again, etc.)
Suppose I write a program that uses FIX 2 as default.
Is there a way to store actual format, use FIX 2, and restore precedent format at the end of the program?
I guess no, but I want to here from you before giving up.
Thanks in advance.
-- Antonio
Re: HP-35S programming
Message #2 Posted by George Bailey (Bedford Falls) on 8 Aug 2008, 5:00 a.m.,
in response to message #1 by Antonio Maschio (Italy)
I don't know of any flag that indicates the FIX/SCI/ALL-status.
But I just thought of a way to at least check the FIX status at program start:
Take for instance 0.1111111111111, use RND on it to cut off any digit that is past the FIX value and than check for the first remaining digit. FIX 4 and RND would give 0.111100000000; FIX 6 and RND would give 0.111111000000 and so on...
Message #3 Posted by MikeO on 18 Aug 2008, 9:33 p.m.,
I can't see a way to programmatically set the display format in an elegant way.
MikeO
Message #4 Posted by George Bailey (Bedford Falls) on 19 Aug 2008, 1:49 a.m.,
in response to message #3 by MikeO
MikeO
If you have found out the format that was preset in the way I described above, you then can do some comparison tests with the stored value and set the display format value again.
x ENTER /* put value in the display x register
[pseudo code snippet]
0
x=y?
FIX 0
RollDown
1
x=y?
FIX 1
RollDown
2
x=y?
FIX 2
Don't know if that's elegant enough, but should work nonetheless...
Edited: 19 Aug 2008, 2:34 a.m.
Message #5 Posted by Palmer O. Hanson, Jr. on 20 Aug 2008, 1:57 a.m.,
in response to message #4 by George Bailey (Bedford Falls)
In the "olden days" of machines such as the HP-41 and TI-59 which had FIX Ind capabilities we would have judged that a program with all that sequential code was distinctly non-elegant. Unfortunately, the powers that be didn't offer FIX Ind with the HP-35s so I suspect that your program is as elegant as one can get with that machine.
Message #6 Posted by Paul Dale on 20 Aug 2008, 4:33 p.m.,
in response to message #5 by Palmer O. Hanson, Jr.
An immediate improvement suggests itself: binary search the number of displayed digits. Branches are very cheap step count wise on the 35s.
I did this in a part of the rather long game I submitted soon after I received my 35s.
- Pauli
Re: HP-35S programming - another method
Message #7 Posted by Palmer O. Hanson, Jr. on 20 Aug 2008, 10:17 p.m.,
in response to message #6 by Paul Dale
I did it another way which yields the number of digits in A:
Z001  LBL Z
Z002  3
Z003  1/x
Z004  ENTER
Z005  RND
Z006  -
Z007  LOG
Z008  +/-
Z009  INTG
Z010  STO A
Z011  RTN
Message #8 Posted by George Bailey (Bedford Falls) on 21 Aug 2008, 3:01 a.m.,
- Pauli
Pauli,
even though I'm not the thread starter, I would be delighted if you could outline the binary search method a bit. I was not able to locate your submitted game in the articles or software section...
Thanks, George Bailey
Message #9 Posted by Paul Dale on 24 Aug 2008, 5:49 p.m.,
in response to message #8 by George Bailey (Bedford Falls)
Details about binary searches. Each comparison is eliminates half of the remaining possibilities.
The game is in the archives. Scroll down, you'll not miss it.
I submitted this and others programs to the software library ages ago but no sign of them there yet.
- Pauli
Message #10 Posted by George Bailey (Bedford Falls) on 25 Aug 2008, 3:08 a.m.,
in response to message #9 by Paul Dale
Thanks, Pauli! I remember having seen that huge game of yours 'back in the days'. I must confess that I was a little reluctant to work through 700 lines - and still am! But thanks to wikipedia I at least now know what a binary search is. ;-)
Message #11 Posted by MikeO on 20 Aug 2008, 10:34 p.m.,
That's about the size of it. Well, at least there's enough extra program memory to write a somewhat lengthy subroutine to do this. ;)
Good tips from everyone on this!
