HP Forum Archive 18
HP35s missing keystrokes?
Message #1 Posted by Brad Davis on 3 Dec 2007, 12:17 p.m.
Forgive me if this has been covered, but I looked briefly and didn't see anything about it.
I've had my 35s for about 3 months and like it quite a bit. However, I am pretty sure it's missing a few keystrokes. I tend to miss more calcs with it than my 48G. It was widespread enough to cause me to experiment a little.
Here's a great example. I started with 9.7847 on the stack and then tried to calc the simple product: .626(5)(2)/4.45 I ended up with some goofy answers like 30.626 or 6.882 a couple of times.
I actually resorted to video recording the display and keystrokes and ran through the calc about 10 times, going at a natural, but very fast speed. I could very clearly see and hear the click when the 2 was pressed, but it didn't register a couple of times. Of course, the product was multiplied by 9.7847, causing an error.
I'm pretty sure it is actually missing keystrokes, although I can't just sit there and strike 2 over and over and cause an error. Has anybody else dealt with this yet?
Re: HP35s missing keystrokes?
Message #2 Posted by Tom Mathes on 3 Dec 2007, 3:09 p.m.,
in response to message #1 by Brad Davis
I see a similar issue with my 35S on the "enter" key and the number 4. It depends on if I press firmly or not on the Enter key. A firm press results in no problems, a light touch (even if I heard the key click) can sometimes mean a missed key. Same goes for the 4 key.
Message #3 Posted by Karl Schneider on 3 Dec 2007, 10:35 p.m.,
Hi, Brad --
The HP-35s I purchased in August doesn't seem to miss keystrokes (at least noticeably), but the one I received in September requires a firm press on "0".
-- KS
Message #4 Posted by Patrick Rendulic on 4 Dec 2007, 2:08 a.m.,
Hello. My 35s also misses keystrokes. I noticed this when adding numbers at a fast speed (my usual speed when working ;)). In my view the software misses the keys. Conclusion, no more 35s for me. I stick with my 32sii, a calculator that I can trust!
Message #5 Posted by Brad Davis on 4 Dec 2007, 11:56 a.m.,
in response to message #4 by Patrick Rendulic
Interesting. One very weird thing is that I can't make the calculator miss a key just by sitting there and pressing it. I also can't make it miss a key by holding down one and pressing another. It even works when I do something like press 1, press and hold Enter, press 2 then +. It seems extremely robust.
Still, I'm almost completely sure it's not registering a keystroke just every now and then, but it's always during real calculations--which seems to strongly suggest user error. It always seems to happen during easy calcs, like a product of 3-4 numbers, which also implies that I'm making mistakes.
Message #6 Posted by Mark Storkamp on 4 Dec 2007, 12:20 p.m.,
I've noticed it on mine as well. As a test I've cleared the stack, typed in a number, then pressed the enter key firmly but quickly 3 times. On rare occasions it will miss one of the enters. I'm personally convinced it is a software/firmware issue since I know I'm making 3 firm distinct key-presses.
Message #7 Posted by Stefan Vorkoetter on 4 Dec 2007, 1:53 p.m.,
I've found the same problem, sometimes with the zero key, sometimes with the decimal point key. I too suspect it's a firmware bug wherein it fails to register extremely short keypresses.
I wonder if hot-rodding the 35s might fix this problem.
Stefan
Message #8 Posted by Tom Mathes on 4 Dec 2007, 2:55 p.m.,
in response to message #7 by Stefan Vorkoetter
Firmware? Perhaps, but since we're seeing different keys it sounds more like a marginal mechanical design/manufacturing issue to me (namely the keyboard) or a combo of electronics and keyboard.
Message #9 Posted by Brad Davis on 4 Dec 2007, 8:00 p.m.,
... I wonder if hot-rodding the 35s might fix this problem. ...
How would one go about doing this?
Message #10 Posted by Stefan Vorkoetter on 4 Dec 2007, 9:20 p.m.,
in response to message #9 by Brad Davis
There was a post the other day about speeding it up by up to 50% by changing the value of R1 on the main board.
Message #11 Posted by Stan Fuller on 15 Dec 2007, 8:22 a.m.,
Is it missing keystrokes... or is it stopping itself mid-crunch when the next button is pressed? I cleared the stack and tried the following several times:
10 enter 3 * 6 /
Using a rapid keystroke, it consistently returns a value of 0.0000. If I slow it down, I get the correct answer of 5.0000. I took it a step further by performing the same calc with 1, 2, 3, etc. in all the stack registers. This is what I got:
stack filled with 1's => 0.0333 (or 1/30), stack filled with 2's => 0.0667 (or 2/30), stack filled with 3's => 0.1000 (or 3/30) ... etc
Too bad HP doesn't simply have an email contact for product gripes. I was just starting to like this calc...
Message #12 Posted by Stan Fuller on 15 Dec 2007, 8:35 a.m.,
in response to message #11 by Stan Fuller
Duh... I'm an idiot. it IS missing a keystroke. The "6" key in this case:
stack filled with 1's => 10 enter 3 * [1] / = 0.0333 (or 1/30)
stack filled with 2's => 10 enter 3 * [2] / = 0.0667 (or 2/30)
stack filled with 3's => 10 enter 3 * [3] / = 0.1000 (or 3/30)
[stack value used when the "6" key was missed]
Sorry for the incorrect post.
Edited: 15 Dec 2007, 8:37 a.m.
Message #13 Posted by Brad Davis on 15 Dec 2007, 9:46 p.m.,
in response to message #12 by Stan Fuller
Stan, that's interesting. I can crank that equation as fast as possible and it doesn't seem to miss. I *think* mine's missing the decimal most often. These intermittent, inconsistent problems are the worst!
I've been concentrating on punching it fast but smoothly and my problems seem to be going away. It might be that I'm punching it barely slowly enough to eliminate them.
Message #14 Posted by Tom Mathes on 17 Dec 2007, 10:28 a.m.,
in response to message #13 by Brad Davis
Mine misses the ENTER key occasionally and the "4" key more often. Speed is one thing that affects it (sometimes), but how hard I press seems to be a bigger issue. Harder presses result in rarely a missed keystroke.
The problem seems random as to which key is being missed since we're seeing different keys but a similar condition as to what makes it a missed keystroke. That implies (to me at least) it's more a mechanical design/manufacturing problem and not so much an electronic problem.
I still like the calc, just disappointed with the missed keystrokes. I'd prefer the 33s keyboard just since I knew it never missed my keystrokes.
Edited: 17 Dec 2007, 10:30 a.m.
Message #15 Posted by Thomas Radtke on 17 Dec 2007, 11:10 a.m.,
in response to message #14 by Tom Mathes
I guess that's just some dirt from production inside the domes. You could try Randys procedure to clean it in an ultrasonic bath with A.dest.
At a second (electronics or programming) level, the 35s actually misses keys when pressed very fast. IIRC, the binary operators are concerned while numeric keys doesn't have the problem to this degree.
Message #16 Posted by Chris Haltiner on 17 Dec 2007, 12:02 p.m.,
I'm seeing the Stan's problem exhibited with the 2, 3, 5, and 6 keys. I can get the missed keystroke to happen consistently and I can slow down entry to a point where it will not happen. I think this explains the couple of missed keystrokes I have experienced with the HP 35s.
Message #17 Posted by Stefan Vorkoetter on 17 Dec 2007, 12:14 p.m.,
in response to message #16 by Chris Haltiner
Could it be that the 35s just doesn't scan the keyboard fast enough? This would let you press and release a key in between scans, in which case it wouldn't register.
Stefan
