HP Forum Archive 18
Calendar program for 50g
Message #1 Posted by Jeffc on 21 Nov 2007, 10:50 a.m.
Hi all,
Does anyone know of a calendar program that will run on a 50g?
Thanks Jeff
Re: Calendar program for 50g
Message #2 Posted by Giancarlo (Italy) on 21 Nov 2007, 12:31 p.m.,
in response to message #1 by Jeffc
Hi Jeff.
Please search the string "calendar" on hpcalc.org and you'll end up with some 50 files; just check the "49/50" check-box and you'll get 18 files among which I guess you can find sevarl helpful softwares :-)
Hope this helps.
Best regards.
Giancarlo
50g Emulators
Message #3 Posted by jcook on 30 Nov 2007, 9:11 p.m.,
in response to message #2 by Giancarlo (Italy)
Giancarlo, I've had a 50g emulator working before but now can't seem to get one running on a new PC. I've downloaded the EMU48 program (1.46) and installed it. I found a ROM file and placed it in the EMU48 folder and also in a new ROM folder within the EMU48 folder. I've tried different names such as ROM.e49 and ROM.48g and now get the following compile message when I try to run the emulator:
This graphic is by Casey Patterson. pattersc@gulftel.com
Come to my page to get more graphics for your Win48!!!
http://www.gulftel.com/~pattersc/win48/
A few improvements by Sebastien Carlier, the author of Emu48. Please visit the Emu48 Official Homepage : http://www.epita.fr/~sebc/Emu48/index.html
Thanks for using Emu48 !
========================================================== Title: Casey's Gx with Toolbar and Touch Screen Author: Casey Patterson && Sebastien Carlier Calculator Model : G Rom ROM.48G Loaded. Patch BEEP.48 Loaded Bitmap cp_48g3.bmp Loaded. Debug Off Packed ROM image detected. Press Cancel to Abort.
The EMU48 program will not let me go further. Help! What am I doing wrong? Also, is there a way to simply use an actual 50g to connect to a PC or projector so I can display the actual calculator's screen? If not I guess I'll have to use the emulator for my classes.
Also, How do I get the and load teh KML skin that makes it look and act like a 50g?
Please also reply to my email at jcook@sageridge.org Thanks, Jon Cook Math Teacher
Re: 50g Emulators
Message #4 Posted by Egan Ford on 30 Nov 2007, 11:27 p.m.,
in response to message #3 by jcook
http://www.debug4x.com/
Message #5 Posted by S. Martin on 21 Nov 2007, 1:11 p.m.,
Try this one:
Organizer 1.1
Highly recommended!
