HP Forum Archive 17
HP 50g stack control
Message #1 Posted by rocco lagioia (Italy) on 7 July 2007, 2:35 p.m.
ok....i had to write this again after i read the "term of use". Let's say that I was not too polite with the HP engineers!!!
I have been using the 28S for 20 years. I loved it. Unfortunately does not work any more. Two weeks ago I bought the 50g. I shall use british understatement: "it's not my favorite calculator" !!! Bulcky, heavvy, big....
But what is even worst it seems I have to press 4 or 5 keys to manage to pick a number from the stack.
Is there any way to put the stack control commands in the function keys? This was normal with the 28S.
Anyone can help me? thanks
Re: HP 50g stack control
Message #2 Posted by Gerson W. Barbosa on 7 July 2007, 4:18 p.m.,
in response to message #1 by rocco lagioia (Italy)
Just set flag -117:
-117 SF
or
[MODE] [FLAGS] then check 117 to change from CHOOSE boxes to Soft MENU. Then [Left Shift] [PRG] [STACK]
HTH,
Gerson.
Edited: 7 July 2007, 4:21 p.m.
Message #3 Posted by James M. Prange (Michigan) on 7 July 2007, 10:58 p.m.,
Well, it's "normal" with the 50g too. LeftShift PRG followed by the STACK menu key give you a menu of the stack commands. Other than that, with the standard "stack display" (no "special environment" active), pressing the CursorUp key invokes an "interactive stack" environment, and even while in a "special environment", pressing the HIST key invokes an "interactive stack" environment.
As Gerson noted, you'll probably be more comfortable with flag -117 set, for "Soft MENU" instead of the default "CHOOSE boxes".
Of course, this applies to "RPN" mode; I wouldn't know about "ALG" mode.
James
Message #4 Posted by Matthew W. Milligan on 8 July 2007, 7:20 a.m.,
I frequently use the PICK function to grab numbers from the stack. My solution is to use a CUSTOM menu that has my most used commands - one of which is PICK.
To create a custom menu you save a list of commands and/or functions with the name CST. Then left-shift MODE turns this list into your active soft menu for use with function keys.
