HP Forum Archive 17
Looking for HP97 printer gear
Message #1 Posted by Doug Braun on 28 Mar 2007, 11:40 p.m.
I managed to successfully do the O-ring repair on my HP97's card reader, but two days later that plastic gear in the printer started falling apart.
Is that replacement gear still available from pic-design.com? Is that still the best way to repair it, or is there some other source?
Thanks,
Doug
Re: Looking for HP97 printer gear
Message #2 Posted by Etienne Victoria on 29 Mar 2007, 2:12 a.m.,
in response to message #1 by Doug Braun
Hello Doug,
I use one from GHW that I drill to adjust the center hole (see below).
Left: Broken gear, Middle: GHW gear, Right: drilled gear.
This works fine in my Hp-92 (daily use) and Hp-97.
More details on the procedure on Isabelle's site
Etienne
Edited: 31 Mar 2007, 10:00 a.m. after one or more responses were posted
Message #3 Posted by marais on 29 Mar 2007, 3:04 a.m.,
in response to message #2 by Etienne Victoria
Hi Etienne, how did you find the right drill for the job? GHW is a very recommended shop, I ordered five of these.
Andreas
Message #4 Posted by Dia C. Tran on 29 Mar 2007, 9:44 a.m.,
in response to message #3 by marais
Can anyone sell me one of these gears predrilled?
Message #5 Posted by Ignazio Cara (Italy) on 29 Mar 2007, 3:50 p.m.,
in response to message #4 by Dia C. Tran
Hello, send me your address to ignaziocaraNOSPAM@tiscali.it, after removing NOSPAM, obviously. I will send you a predrilled gear for free. Regards.
Edited: 29 Mar 2007, 3:52 p.m.
Message #6 Posted by Etienne Victoria on 30 Mar 2007, 2:29 a.m.,
Hi Andreas,
I put the gear on a Dremel 212 drilling table and use the ref. 628-1,6mm drill at 15000 rpm.
Then, to secure the gear on the printer, I put a rivet cap on the axis instead of the low quality breakable original Hp locking part.
I forgot to put a picture of the tool and rivet on Isabelle's site.
Kind regards from France.
Etienne
Message #7 Posted by Steve Borowsky on 30 Mar 2007, 6:56 p.m.,
in response to message #6 by Etienne Victoria
But, I thought it has to be drilled to 1,92mm?
Message #8 Posted by Ignazio Cara (Italy) on 31 Mar 2007, 1:56 a.m.,
in response to message #7 by Steve Borowsky
The gear must be drilled at 2,35-2,40 mm, IMO.
Ignazio
Re: Looking for HP97 printer gear, Ignazio is right!
Message #9 Posted by Etienne Victoria on 31 Mar 2007, 4:05 a.m.,
Hi all,
Ignazio is right!
I refer to the GHW 753030 gear which is the one I've pictured. The inner diameter is already 2,00mm.
I have remeasured the original Hp gear from my 92 & 97s and it is indeed around 2,30.
All my apologies for posting an incorrect dimension. Isabelle's site has been corrected accordingly.
Thank you Ignazio.
Etienne
Edited: 31 Mar 2007, 4:11 a.m.
Message #10 Posted by Dia C. Tran on 6 Apr 2007, 8:08 a.m.,
in response to message #9 by Etienne Victoria
I just received the gear from Ignazio and my calc now works beautifully. Thank you Ignazio, didn't know that you had to send it all the way from Italy.
Message #11 Posted by Doug Braun on 6 Apr 2007, 9:30 p.m.,
Thanks to everybody for all the advice. Before I saw your reply, I ordered a couple of gears from SDP:
http://www.sdp-si.com/D790/PDF/D790C01036.pdf
They arrived in only a couple of days, and my printer is already fixed! Their gear is probably identical to the one that PIC-Design sells. I had to trim one end, and use a 3/32"-to-1/8" sleeve. For the sleeve, I used a bit of brass tubing that I got at a hobby store. It was 3/32" ID and 1/8" OD, and it fit perfectly.
I also rebuilt my battery pack with the assembled cells from Digi-Key.
Thanks again to hpmuseum.org and this forum for all the help!
Doug
