HP Forum Archive 17
can i use a HP41 printer charger with a HP-97?
Message #1 Posted by Hugo on 8 Mar 2007, 3:24 a.m.
I recently found an HP 97 without peripherals and i wander if i can use a charger of the HP41 printer (82143A) to test it? Can i do so without risk to damage the HP97? Does anyone have experience with this? thanks for helping me out!
Re: can i use a HP41 printer charger with a HP-97?
Message #2 Posted by Klaus on 8 Mar 2007, 3:53 a.m.,
in response to message #1 by Hugo
Yes, you can use this charger
Message #3 Posted by Les Wright on 8 Mar 2007, 6:08 a.m.,
Same charger, same battery pack. Be sure to have a working battery in the 97, otherwise it will behave strangely--even on AC, the 97 needs a working battery back installed to properly complete the circuit and work correctly.
Les
Message #4 Posted by Hugo on 9 Mar 2007, 4:52 a.m.,
in response to message #3 by Les Wright
thanks, i will give it a try!
