HP-71B keyboard repair Message #1 Posted by Klaus on 3 Sept 2006, 1:46 p.m.
Recently, I was given a dead HP-71B by a friend. This friend is a gardener, and he used this calc (or computer?) outdoors. The little beast had leaked batteries and had a good amount of soil in it. I cleaned the battery leakage, and let the calc rest in water for half an hour. After letting it dry over night, I tried to start it: All segment were lit, and it didn't react on keypresses. Some of the keys I pressed stayed pushed-down, because the dirt inside the keyboard blocked them. So I decided to repair the keyboard:
The heatstakes holding the keyboard PCB together could be removed with a pocket knife. You slide the knife under the mushroom head, and turn the knife. This breaks the plastic of the mushroom while leaving the heatstake as tall as before. With this method, I broke about 5 heatstakes, the rest were only poles without their mushroom head. Cleaning the now dismanteled, well-built keyboard (which was very dirty) was easy, and so was putting the thing together. I decided to test the HP-71B first, before melting the heatstakes of the keyboard. It came on, and reacted to keystrokes. However, without the pressure on the keyboard, some keys bounced, and sometimes pressing one key also registered the key above it (pressing 'A' displayed 'AQ').
Even without melting the heatstakes, keyboard-feeling was pretty good. This is due to the fact that there is very little room between the keyboard PCB and the boxes containing the 'Front ports'. So I decided to leave the heatstakes alone, and just put some elastic material (mine was 2mm foil for isolating walls) onto the front port boxes and the battery compartment. This did the trick.
Keyfeel is now as good as on my HP-11c, however the foil was a bit too thick, so the case is now slightly bent. But I was able to clean everything inside the keyboard (and there was a lot of dirt) and the front half of the case, so the keys and the display look like new.
The whole procedure (dismantling, cleaning an putting together took about 2 hours). Now I am seeking a Forth/Assembler module to do something useful with it!
I hope this story helps people who have a bad keyboard on the HP-71B.
Have a nice week! Klaus
