Re: Just a suggestion Message #6 Posted by Steve on 7 Apr 2003, 12:27 p.m., in response to message #5 by Vieira, Luiz C. (Brazil)
I tried an experiment, I cut the right edge (1/2" or so) off the paper. After several attempts of the paper getting jammed, I finally got it to print on the narrow paper. The result was the same, with the right most character being lighter than the rest of the line. This was a good suggestion however, since the paper I'm using is old and it's storage over the last 20 years is not known to me. So, thanks Luiz.
I then attempted to gently move the right side of the platen closer to the print head (while the head was on the left side). Since it is spring loaded, it pretty much returns to it's original position, and the result was the same, the right most character was lighter.
I'm going to experiment more tonight, but I don't really see a way to adjust the platen permanently. Thoughts?
Steve
