HP Forum Archive 11
Soft Forth for the HP-71B
Message #1 Posted by J-F Garnier on 18 Mar 2003, 3:22 a.m.
In a recent thread http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv010.cgi?read=28643, I mentionned the existence of the soft Forth for the HP-71B (soft Forth means that it can be used in a standard RAM or EPROM module).
I looked into my archive and recovered the Soft Forth. Version is VER$='SFTH:E'. When I enter Soft Forth by executing 'SFTFORTH', 'HP-71 Soft FORTH E' message is displayed. I also have a preliminary manual (release 2.4, dated Feb 3, 1986).
Does someone have a more recent version of Soft Forth code and/or manual, or an application built with Soft Forth?
Thanks for any information.
J-F
Re: Soft Forth for the HP-71B
Message #2 Posted by Mike (Stgt) on 18 Mar 2003, 5:11 a.m.,
in response to message #1 by J-F Garnier
Sorry, I have no Soft Forth. Only a question: T'a le temps pour le rencontre Berne? See www.mfk.ch
Ciao.....Mike
Message #3 Posted by Philip on 18 Mar 2003, 9:48 a.m.,
Could you make those files available?
Message #4 Posted by andy on 18 Mar 2003, 7:02 p.m.,
Can you make "soft forth" available?
Is it a LEX file?
Message #5 Posted by J-FGarnier on 19 Mar 2003, 3:26 a.m.,
in response to message #4 by andy
Soft Forth needs a 64k RAM module (not 2 x 32k, a real 64k one). It is made of 2 files: a SFTFORTH LEX file and a FORTHEADER FORTH file. It creates a FORTHSYS FORTH file as the first RAM file (similar to FORTHRAM with the FORTH/ASS module).
From what I understood from the documentation, the Forth module is still needed to develop the application. Soft Forth is only a way to make Forth based applications that can run without the Forth module.
Actually, I never run Soft Forth until a few days ago, because I don't have a 64k RAM module. I used my Emu71 to test it (I modified Emu71 to emulate 64k/128k module, just in order to test Soft Forth!).
I read the original 17 years old floppy disk without any problem, I even didn't have a backup copy!
I will put some information on my site soon. I will let you now.
J-F
Message #6 Posted by andy on 19 Mar 2003, 12:41 p.m.,
in response to message #5 by J-FGarnier
Please let us know when you make it available (would you mind emailing me a copy sooner?).
I have a 128k RAM module...do you think it will work with that?
thanks,
Andy
Message #7 Posted by kim on 19 Mar 2003, 3:34 p.m.,
Monsier Garnier
Where is you Web page?
Kim
Message #8 Posted by J-F Garnier on 20 Mar 2003, 6:50 a.m.,
in response to message #7 by kim
http://membres.lycos.fr/jeffcalc/
Regards.
J-F
