HP Forum Archive 08
HP 33e and 33c battery packs
Message #1 Posted by Kevin on 18 Aug 2002, 5:06 p.m.
Does anyone know a source for battery packs for the 33e and 33c? I have several of them, with chargers, but no battery packs.
Thanks!
Re: HP 33e and 33c battery packs
Message #2 Posted by Vassilis Prevelakis on 19 Aug 2002, 6:25 a.m.,
in response to message #1 by Kevin
Series 30 battery packs are probably the easiest to construct. You take two AA rechargable cells with flat tops (preferably with metal wire tabs if you can find them).
You then place them one next to the other and solder the positive end of one with the negative end of the other
You then use hot glue to join the batteries on the top side and only a third way on the bottom (to allow of the orientation tab on the bottom of the batery compartment).
Make doubly sure that the pack orientation is correct.
