HP Forum Archive 08
HP 41 private programm
Message #1 Posted by Ulrich Schaefer on 28 July 2002, 1:39 a.m.
I have an old (navigation)programm (cards) for my HP-41CX which I want to modify, but it says "private" in the moment I want to edit it. How to overcome this problem?
Re: HP 41 private programm
Message #2 Posted by Vieira, Luiz C. (Brazil) on 28 July 2002, 2:20 a.m.,
in response to message #1 by Ulrich Schaefer
Hi;
have a look here. For sure, the answer is there.
Cheers.
Message #3 Posted by Ulrich Schaefer on 28 July 2002, 4:35 a.m.,
in response to message #2 by Vieira, Luiz C. (Brazil)
Thank you very much Luiz!
Message #4 Posted by HrastProgrammer on 1 Aug 2002, 1:57 a.m.,
This shorter procedure worked for me just fine:
1. Load the program from the card (to be the last program in memory).
2. GTO ..
3. PRGM CAT 1 R/S (immediately after CAT 1)
4. SST (until you see .END. REG xxx)
5. DEL 001 (at .END. REG xxx)
6. <- (back arrow)
7. PACK
Message #5 Posted by Vieira, Luiz C. (Brazil) on 1 Aug 2002, 9:52 a.m.,
in response to message #4 by HrastProgrammer
Hi;
I tried this sequence (or somethink close to it) some times, and it worked only with one of the 41's I tested. it seems to me (I think I read it somewhere) a slight change in the 41's OS did not allow it to work; I'm not sure, it must be checked.
It makes me remember the way the first enthusiasts got into Synth Prgm: by removing memory modules in the 41C. The kbd-only procedures were needed with the advent of the 41CV: no way to change mem modules.
How I miss this kind of brainy activity... not in my brain (going fine so far), just in the neighborhood. And I miss the release of this sort of teasing little boxes, too.
Cheers.
Message #6 Posted by Mike (Stgt) on 2 Aug 2002, 7:52 a.m.,
in response to message #5 by Vieira, Luiz C. (Brazil)
If it worked on one of your HP41 this should be enough to de-private the program. ;-)
If you have a ZEN-ROM at hand, you may use RAMED to change the END of your PROGRAM. Or take your program to an emulator of the HP41 (there are some useful arround) and manipulate it there.
Ciao.....Mike
