HP-12C/12C platinum/15C CE date of manufacture
05-14-2024, 05:34 PM
My 3 modern made Voyager calculators have no serial no.
HP-12C,
2x CR2032, battery door with captive screw
KCC-REI-HPK-HSTNJ-KN11
RMN HSTNJ-KN11
L/NO. 9CJ251 (white glued label)
HP-12C platinum
RMN HSTNJ-KN11
L/NO. 9CJ310 (white glued label)
HP-15C CE
HSTNJ-KN13
L/NO. 9CJ323 (white glued label)
Collector's Edition No. 06506
Each is made in Philippines, as printed on the bottom of the device.
Is it possible to get some information about their date of manufacture? As far as i know the L/NO. is not a serial number.
Uwe
05-14-2024, 05:42 PM
RE: HP-12C/12C platinum/15C CE date of manufacture
The Lot number does give you an approximation of the date of manufacture.
The methods for interpreting it have changed over the years, so someone else will have to confirm.
You indicated that the 12C has a screwed battery cover, that makes it very recent, since Moravia and Royal licensed the calculator products from HP.
05-15-2024, 01:48 AM
There is no way to get precise production dates, however if it helps, these were all made in 2022-2023, as that is when mfg. shifted from HP to Moravia, which were the firs to include the retaining screw on the battery door.
05-15-2024, 06:35 AM (This post was last modified: 05-15-2024 06:37 AM by linq2008.)
9CJ251(2022,week 51),
9CJ310(2023,week 10),
9CJ323(2023,week 23),
05-15-2024, 12:06 PM
(05-15-2024 06:35 AM)linq2008 Wrote:  9CJ251(2022,week 51),
Well that's a lot more precise than my arm waving! Smile
Thanks for braking the code and sharing the news here.
05-16-2024, 12:21 PM
Thank you very much! Smile
