Bézier Curves (Bezier curves)
01-16-2018, 10:04 PM (This post was last modified: 01-16-2018 10:12 PM by StephenG1CMZ.)
A program for generating and drawing Bézier curves...
Stephen Lewkowicz (G1CMZ)
01-16-2018, 10:08 PM
RE: Bezier Curves
Bezier curves V0.1 allows the points on a Bezier curve to be generated and drawn.
 LOCAL CRID:="Bézier V0.1 StephenG1CMZ 2018";
 //LOCAL ImpSTEPSZ:=1/(10000-2);//Most Detailed-List Limit
 //! Android: Insufficient Memory may occur.
 //These steps allow a spline along a diagonal
 //LOCAL GSTEPSZ:=1/(4406-2); //4K
 //LOCAL GSTEPSZ:=1/(2203-2); //HD
 //LOCAL GSTEPSZ:=1/(800-2);//VGA
 EXPORT GSTEPSZ:=1/(400-2);//QVGA
 //0..1 ALSO IMP>0.001=10000 PTS
 EXPORT ROTMATRIX:=[[1,0],[0,1]];//DEFAULT: NO ROT (ONLY USED WITH CN=1)
 LOCAL CN:=1;//0=POINTS 1=LINES (EXAMPLES)
 //NB PROCEDURES RETURN COMPLEX REAL (X,Y) VALUES
 //WHICH YOU MIGHT WISH TO PIXELLATE
 //PROCEDURES PREFIXED G GENERATE CURVE POINTS
 //PROCEDURES SUFFIXED 1 GENERATE 1 POINT
 //POLYBEZIER NOT IMLEMENTED:ADDITIONAL PARAMETERS IGNORED
 GETPT(N1,N2,PERCY)
 //FRACTION ALONG LINE:X OR Y
 //USED BY BEZIER PROCS
  LOCAL DFF:=N2-N1;
  RETURN (N1+(DFF*PERCY));
 EXPORT GBezierQUAD1 (XX,YY,PERCY)
 //Generate a point along a Bezier Quadratic curve
 //PERCY AND II: 0..1
  LOCAL XA,YA,XB,YB;
  LOCAL II:=PERCY;
   // FIRST CONSTRUCT GREEN LINE
   XA:=GETPT(XX(1),XX(2),II);
   YA:=GETPT(YY(1),YY(2),II);
   XB:=GETPT(XX(2),XX(3),II);
   YB:=GETPT(YY(2),YY(3),II);
   //GENERATE BEZIER POINT
   RETURN ((GETPT(XA,XB,II)),(GETPT(YA,YB,II)));
 EXPORT GBezierQUAD(XX,YY)
 //Generate Bezier Quadratic curve
 //XY: 1 AND 3 ON CURVE. 2 CONTROLPT.
  LOCAL II;
  LOCAL XA,YA,XB,YB;
  LOCAL PTS:={};
  //FOR EACH
  FOR II FROM 0 TO 1 STEP GSTEPSZ DO
   PTS(0):=GBezierQUAD1(XX,YY,II);
  END;//FOR
  //ENSURE PT3 ON CURVE
  PTS(0):=GBezierQUAD1(XX,YY,1); //(XX(3),YY(3));
  RETURN PTS;
 EXPORT GBezierCUBIC1(XX,YY,PERCY)
 //Generate a point along a Bezier Cubic curve
  LOCAL II:=PERCY;
  LOCAL XA,YA,XB,YB,XC,YC;
  LOCAL XM,YM,XN,YN;
   // FIRST CONSTRUCT GREEN LINES
   XC:=GETPT(XX(3),XX(4),II);
   YC:=GETPT(YY(3),YY(4),II);
   //BLUE LINE
   XM:=GETPT(XA,XB,II);
   YM:=GETPT(YA,YB,II);
   XN:=GETPT(XB,XC,II);
   YN:=GETPT(YB,YC,II);
   RETURN (GETPT(XM,XN,II),GETPT(YM,YN,II));//X AND Y
 EXPORT GBezierCUBIC(XX,YY)
 //Generate Bezier Cubic curve
 //XY: 1 AND 4 ON CURVE. 2 AND 3 CONTROL PT.
  LOCAL II;
  LOCAL PTS:={};
  //FOR EACH
   PTS(0):=GBezierCUBIC1(XX,YY,II); //X AND Y
  END;//FOR
  //ENSURE PT4 ON CURVE
  PTS(0):=GBezierCUBIC1(XX,YY,1); //(XX(4),YY(4));
  RETURN PTS;
 EXPORT DRAWC(PTS,COLR,CONN)
 //DRAW POINTS CONNECTED
 //PTS: (X,Y) AS COMPLEX ie LINE FORMT
 //CONN 0: POINTS 1 BY 1
 //CONN 1: LINES ALL AT ONCE
 //(GUARDS AGANST GAPS)
 //TBD: IMPLEMENT _P AND NON_P VARIANTS
  LOCAL II;
  LOCAL LINESLST:={};
  CASE
   IF SIZE(PTS)==0 THEN //NOTHING TO DRAW
   IF CONN==0 OR SIZE(PTS)==1 THEN //POINTS
    FOR II FROM 1 TO SIZE(PTS)  DO
      PIXON_P(RE(PTS(II)),IM(PTS(II)),COLR);
      //WAIT(1);//ANIMABLE
   END; //POINTS
   IF CONN==1  THEN //LINES
     LINESLST:=MAKELIST({II-1,II},II,2,SIZE(PTS));
     LINE_P(PTS,CONCAT(COLR,LINESLST),ROTMATRIX);
     //LINE_P(G9,PTS,CONCAT(COLR,LINESLST),ROTMATRIX);
   END; //LINES
   DEFAULT
   //UNKNOWN CONN
  END;//CASE
 EXPORT IsOnCurve(Points,Point,Rounding)
 //Is PT on curve described by PTS
 //Points:Points comprising curve
 //Point: Search Point (Complex XY)
 //Rounding: −12..12 allows inexact real matches
 //NB if points change, conclusion may
 //Enhancements: Consider alternatives to rounding
  LOCAL RND:=Rounding;
  RETURN POS(ROUND(Points,RND),ROUND(Point,RND));
 EXPORT BezierExample()
 LOCAL TM,GTIME;
 LOCAL PTS;
 LOCAL COLR:=#FF00FF;
 LOCAL GSTEPSZ_SAVE:=GSTEPSZ;
 GSTEPSZ:=1/(200-2);//LOCALVALUE FOR DEMO
 RECT_P();
 TEXTOUT_P(CRID,0,220);
 TEXTOUT_P("Generate",0,0);
 DRAWC({(320/2,240/2)},COLR,CN);//TEST 1 PT
 DRAWC({},COLR,CN);//TEST NULL
 TEXTOUT_P("Draw",160,0);
 TEXTOUT_P(TEVAL(PTS:=GBezierQUAD({10,80,240},{200,100,150})),0,20);
 TEXTOUT_P(TEVAL(DRAWC(PTS,COLR,CN)),160,20);
 TEXTOUT_P(SIZE(PTS)+" Points/Bézier",0,200);
 TEXTOUT_P(TEVAL(PTS:=GBezierCUBIC({10,0,150,240},{200,20,20,150})),0,40);
 TEXTOUT_P(TEVAL(DRAWC(PTS,COLR,CN)),160,40);
 TEXTOUT_P(TEVAL(PTS:=GBezierQUAD({100,250,250,325},{100,100,200,350})),0,60​);
 TEXTOUT_P(TEVAL(DRAWC(PTS,#FF0000,CN)),160,60);
 GSTEPSZ:=GSTEPSZ_SAVE;
 //PRINT();
 //PRINT("RESULT:POS is "+IsOnCurve({(1,2)},(1,2),0));
 WAIT;
 EXPORT BEZIER()
  BezierExample();
Quadratic Bezier and Cubic Bezier are implemented, but Polybeziers are not yet implemented.
01-16-2018, 11:13 PM
RE: Bézier Curves (Bezier curves)
Oh memories!
I learned about Bezier curves about 10 years ago, I used them as a rough approximation of the catenary curve, to draw some wires in a game. Later on I used polybeziers and splines in other projects Smile
Software Failure: Guru Meditation
Antonio
IU2KIY
01-17-2018, 03:14 PM
When I saw how quickly I got a reply, I was expecting to see "why didn't you use this built-in function?" but I didn't find one.
I know I studied Bezier and splines but I have forgotten most of that and I can't recall ever needing them.
03-16-2021, 11:16 PM (This post was last modified: 03-16-2021 11:20 PM by StephenG1CMZ.)
This thread discusses plotting Bezier curves using the plotparam built-in and Parametric App (as
Possible alternative to using this PPL program).
https://www.hpmuseum.org/forum/thread-16...ght=Bezier
Note: If my program gives a syntax error on a line containing "space)", just delete the space character.
08-02-2023, 09:01 AM (This post was last modified: 08-02-2023 09:14 PM by StephenG1CMZ.)
I have now written a Python implementation (intended for matplotlib).
