Function "contains" in HOME and CAS
01-02-2018, 03:15 PM
I've found a different behavior of the function "contents" in HOME and CAS, in the following situation:
L1:={"A","B"}
In CAS
contains(L1,"A") -> 1
contains(L1,"B") -> 2
In HOME
contains(L1,"A") -> 0 !!!
contains(L1,"B") -> 0 !!!
01-02-2018, 03:18 PM
RE: Function "contains" in HOME and CAS
its name is in lowercase, so I think it should be only a CAS command (not Home)...
∫aL√0mic (IT9CLU), HP Prime, 50g, 41CX, 42s, 15C, 12C, DM42 :: Prime Soft. Lib
01-02-2018, 03:27 PM
(01-02-2018 03:18 PM)salvomic Wrote:  its name is in lowercase, so I think it should be only a CAS command (not Home)...
Agreed, but when L1 is filled with numbers instead of strings, it works correctly both in CAS and HOME.
01-02-2018, 03:29 PM
The lower case [CAS] command can work the same way in [Home] if you provide a CAS wrapper:
[CAS]
contains(L1,"A"); ==> 1
[Home]
CAS(contains(L1,"A")); ==> 1
01-02-2018, 06:18 PM (This post was last modified: 01-02-2018 06:22 PM by JMB.)
Ok, I realize that the safe way to execute a CAS function in HOME is to use the structure CAS(CAS_function).
What still bothers me is that you can use the CAS function directly in HOME and, depending on the arguments, get correct or incorrect results. As I said before, when L1 contains numbers instead of strings "contains" works correctly both in HOME and CAS.
01-02-2018, 06:32 PM
(01-02-2018 03:29 PM)DrD Wrote:  The lower case [CAS] command can work the same way in [Home] if you provide a CAS wrapper:
[CAS]
[Home]
How does it work in RPN mode?
01-08-2018, 06:10 AM
home contains(L1, "A") will cause A to be parsed as a CAS command line before the switch to CAS mode and the execution of contains. Assuming that the var A contains 0, what you execute is: contains(L1,0).
CAS(contains(L1,"A")) will not cause a parse of the string.
Subtelties of HOME/CAS interraction :-)
Cyrille
01-08-2018, 07:00 AM
(01-02-2018 06:32 PM)Voldemar Wrote:
(01-02-2018 03:29 PM)DrD Wrote:  [Home]
'contains(L1,"A")' Enter
CAS(1) Enter
01-08-2018, 07:56 AM (This post was last modified: 01-08-2018 07:57 AM by Carlos295pz.)
It is as indicated by Cyrille, it is due to the topic of Home/CAS interaction, since strings are interpreted by using CAS commands such as contains, head, solve, etc. (similar post http://www.hpmuseum.org/forum/thread-8149.html)
It can be said that all CAS functions (~ lowercase commands) will present this interpretation of a string data. This article Home/CAS-Spanish may be useful.
Correct use under this consideration:
contains(L1,("A"))
contains(L1,'"A"')
contains(L1,"A"+"")
LOCAL Strg="A"
contains(L1,Strg)
Viga C | TD | FB
