Access Matrix by row or column
12-28-2017, 11:26 AM
Is there a command to select a specific column or row of a matrix?
Ie in Matlab this works:
A(3, : ) % Extract third row
The colon is used as a wildcard. I cant find a way to do this on the Prime except using SUB(), but that requires you to enter lists containing start and end indices of selected region so is not as convenient as wildcarding.
Actually, for a 2D Matrix, just using A(1) will select the 1st row ,but how to fo this for a column? I tried A(:,1) but this errors.
12-28-2017, 11:38 AM
RE: Access Matrix by row or column
col(M,n) and row (M,n) will do the job.
12-28-2017, 11:48 AM
(12-28-2017 11:38 AM)Arno K Wrote:  col(M,n) and row (M,n) will do the job.
Thanks, I should have checked the catalog!
12-28-2017, 11:49 AM (This post was last modified: 12-28-2017 03:36 PM by salvomic.)
yes. The Help mentions also the possibility to use an interval, but it doesn't give examples how to input the interval (both for row and cols)...
You can also use some code like this one to get a "minor" (giving the row and col to delete: i.e. using minor(2,3) in a 3x3 matrix deletes row 2 and col 3 and returns a matrix with (1,1), (1,2), (3,1), (3,2) ...
#cas
// Minor of a matrix
// r row, c col to delete
minor(m, r,c) :=
  m:= delrows(m,r);
  m:= delcols(m,c);
  RETURN m;
#end
Salvo
EDIT: how should input the interval in row() and col() in Home?
In CAS it's ok row(M2,2..3), a standard way to input an interval: why not implement it also in Home?
∫aL√0mic (IT9CLU), HP Prime 50g 41CX 71b 42s 12C 15C - DM42 WP34s :: Prime Soft. Lib
12-28-2017, 08:19 PM
(12-28-2017 11:26 AM)Stevetuc Wrote:  .....
You can use negative values to select columns: A(-1) selects the 1st column
12-29-2017, 02:45 PM
Thanks, thats concise syntax!
