Function setup
12-26-2017, 04:39 AM (This post was last modified: 12-28-2017 11:40 PM by BryanPiguave.)
Function setup
Hi. Is it possible to change the plot setup using a command in the Function app?
I was working on a programme about LVE for chemical engineering and I wanted to change Xmin, Xmax,Ymin,Ymax. It would be great if these can be changed to share my results in this forum.
Thanks.
Attached File(s) Thumbnail(s)
01-01-2018, 10:49 PM
RE: Function setup
The plot set up is accessible through app variables. This access is documented in the user guide.
01-01-2018, 11:32 PM (This post was last modified: 01-01-2018 11:35 PM by StephenG1CMZ.)
RE: Function setup
If you wanted to do it as a command from Home or within a program, have you tried
Function.Xmin:=123?
(Where Function is the name of the App)
Stephen Lewkowicz (G1CMZ)
Does every Android "improvement" make Android worse?
