There is a change in programmed menu handling between 8151 and 11586 (Android)
11-08-2017, 07:38 PM (This post was last modified: 11-08-2017 07:39 PM by StephenG1CMZ.)
If a new release is imminent, you might want to check out why my Z_LIGHTS program seems to work fine in 8151, but not so well in 11586 (both running on Android), just in case it is something that can be put right.
I have detailed the difference here, but have not yet looked into why it behaves differently.
http://www.hpmuseum.org/forum/thread-503...l#pid82892
Stephen Lewkowicz (G1CMZ)
Does every Android "improvement" make Android worse?
11-10-2017, 09:32 PM (This post was last modified: 11-10-2017 10:11 PM by StephenG1CMZ.)
RE: There is a change in programmed menu handling between 8151 and 11586 (Android)
Cause found...I will start a new thread with a better title and delete this one.
Oh. I cannot delete it.
11-10-2017, 11:53 PM
EDIT/ Full edit/ x Delete? [Delete Now]
Viga C | TD | FB
11-11-2017, 12:17 PM
I have done that. Before, but now I seem to lack permissions.
